Thread: 1.9 CDTI (150) fuel filter change
    Ingleby Barwick
    Default 1.9 CDTI (150) fuel filter change
    A question for anyone who's changed the filter themselves - does a lot of diesel escape when the two fuel pipes are removed from the filter box and do you have to temporarily seal them with something? The guide I have says the pipes should be sealed with a vx tool KM-6015 but I have no idea what one of these is, how much it costs, where to get one from, or whether it's even necessary at all.
    The Haynes manual says just to cover the ends or plug them with something to stop dirt getting in.
    Any advice gratefully appreciated.
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    not a lot escapes at all, just a few drips, you need to more worried about the amount in the filter itself escaping... to cover the ends if your gonna be more than a few minutres something like a plastic bag and rubber band just to seal off the ends will be fine
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Simo87's Avatar
    Jan 2008
    Middle Wallop
    when mine was changed, joint effort between me and my dad a diesel fitter, there was only slight drips of diesel that escaped. and we left it off for a good while aswell while i cleaned the inside of the casing etc etc. wouldnt recommend just taking it off and leaving it there for a few hours but if your taking it out to swap bit of a clean it should be fine.
    simo
    Sep 2009
    Swindon
    How did you guys get the filter case out of the crash box, is there a technique to this?
    Frenchman
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    very tight, but it lifts upwards
    Regular Member Fash's Avatar
    Doncaster
    I remember the 1st fuel filter I changed-was a mondy mk 2, didn't block the pipe ends off properly and ended up with petrol all over my face....bad times, lol
  1. How to change the fuel filter on 1.9 CDTi??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 13:11
  2. vectra cdti sri fuel filter change????
    By Mads in forum Engine & Drivetrain
    Last Post: 20th March 2011, 22:50
  3. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  4. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
  5. Oil and fuel filter Change on a CDTi 3.0 V6
    By pwjolly in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 14:53
vauxhall vectra diesel fuel filter change
fuel filter vectra 1.9 cdti
vauxhall vectra 1.9 cdti fuel filter change
vectra c 1.9 cdti fuel filter change
how to change fuel filter vectra 1.9 cdti
where is the fuel filter on a vauxhall signum 1.9 diesel
vectra c diesel fuel filter change
vectra c cdti fuel filter change
how to change fuel filter on vectra 1.9 cdti
vectra cdti fuel filter change
vectra c diesel how to get filter out of crash box
changing fuel filter on vauxhall vectra
vauxhall vectra 05 1.9 cdti Sri fuel filter
opel vectra c 1.9 cdti fuel filter change
change diesel fuel filter vectra c
best fuel filter for vectra cdti
https:www.vectra-c.comforumshowthread.php94550-1-9-CDTI-(150)-fuel-filter-change
how to change fuel filter on vauxhall vectra 1.9cdti
cdti fuel filter
change fuel filter vauxhall vectra diesel
how to change fuel filter on vectra c 1.9 cdti
astra 1.9 2008 cdti fuel filter replacement
how to bleed fuel filter 2oo5 1.9 cdti vectra
