i have a (52) 1.8LS should i have traction control?
I think its a standard feature across all models, with EBD and other things added on the higher spec models.
i do not have the light when i turn the ignition on, nor do i have the switch??
The switch isn't standard... its a £9 mod from the vx dealer.... you need to pull the blanking plate off the 2nd hole up on the right hand side... if there is a blue plug at the back then chances are you have TC.
I think all models have TC as standard except 1.8 engines ( I don't know why though)
I'm not sure, but I don't think the 1.8 comes with TC. But as Jamie says, if you remove the blanking plate and the blue plug is present, then you have TC. All you need to do then is buy the switch off Vx and voila!
