Thread: Cd70 disc
    Oct 2009
    UK
    Default Cd70 disc
    Does anyone have know where i can buy a cd70 disc? I have a 2007/2008 has all the maps but when I try to use it in my local town no street names come up.
    There was no disc with the car when I bought it.
    Cheers.
    11 Post(s)
    Ebay would be your best bet, but watch out for pirate copies.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Unless your local town is quite new (within 5 years old) then it should show up on the screen.
    Does it only affect your local town??.
    Usually roads don't show up if they haven't been "digitized" yet by the map producers
    Have you got a language disk...you may need to use this or a software update disk...do a system reboot and software clean-up by inserting the language disk or update disk
    when the disk is done, your cd70 will spit it out, just re-insert your map disk and report back if this has solved it or not.
    Failing that, does the GPS symbol with a line through it pop-up..if so, you have a weak or non-existent GPS signal...could be a faulty aerial base or dirty / loose connection.
    Oct 2009
    UK
    Hi I haven't got any other disks, the guy I bought the car from had none or so he said. I will have to try and get the language disk or software update. The streets search is very limited only seems to be picking up major roads in my area. I have tried a further search and the options are still very limited. The GPS signal isn't showing so I guess thats not the problem.
    Cheers.
  1. What cd70 nav disc is best?
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2012, 21:51
  2. CD70 disc
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2011, 23:20
  3. cd70 disc
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 21:17
