Thread: accelerator goes 'flat'
    Oct 2009
    Nuneaton
    Default accelerator goes 'flat'
    Hi everybody........
    My lad has just bought a Vectra 1900cc, Diesel Ls, 2002. When I drove it home after about 5 mins on the road all his dashboard dials returned to zero. When at traffic lights, I turned the engine off and started up again....all was well for a couple of mins and then all went back to zero once more.
    Alongside this I found that I was unable to accelerate past a certain level of revs (while dials were on zero). It would get to about 2700 revs and stay there, whichever gear I was in and how far I pushed down on the pedal.
    When we pulled up again.....turned off the engine and started up again and away we went.....accelerating as fast as we wanted.....until 2 mins later the revs died and so did the dials.
    Anyone come across this before, please?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    its obvioulsy gone into limp mode..............were there any warning lights on the screen ,I would take it back to the garage where you bought it from and get them to ck for fault codes
    Oct 2009
    Nuneaton
    thank you, but no warning lights, well I didnt notice any. Would putting the engine on a diagnosis machine DEFINATELY identify the problem??
    Ta
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    yep thats what they are made for ...it should bring up fault codes,then hopefully lead to a fix ...good luck
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    just had a quick search ...........have you cked your boost hoses ,appeares this is one problem that they split
    WGAF#5
    not sure if the abs/ speed senor having a poor contact would put this into lhm as the vehicle would be unsure as to wether the brakes were working correctly.... this would also cover all the dials dropping as well...
    might be worth checking the connection on the abs unit in the engine bay and spraying some contact cleaner /wd40 in there for good measure
    linky to similar thread
    http://www.vectra-c.com/forum/showth...ighlight=dials
    Oct 2009
    Nuneaton
    I will take all these ideas to my mate at the servicing garage who is having a go at fixing this failure. Thanks for your suggestions and ideas.
    Fortunately, he is doing it free gratis, I hope!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Is it a 1900? As they started replacing the 2.0DTI and 2.2DTI in 2004??
    I say this as the 1900 diesels are not without their faults to say the least.
    Hope it gets sorted.
    Gazza4
  1. No reaction to accelerator
    By Kaz in forum Engine & Drivetrain
    Last Post: 15th January 2013, 22:58
  2. Accelerator pedal
    By Mopar Man in forum Diesel Engine related
    Last Post: 8th December 2011, 20:41
  3. Wheel refurb, flat or not flat B4 lacquer
    By Grumpy1954 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2011, 20:11
  4. Chugging when releasing the accelerator?
    By guskent99 in forum Engine & Drivetrain
    Last Post: 28th March 2010, 20:22
  5. no accelerator!!!
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 5th November 2008, 22:38
