Results 1 to 10 of 11
Thread: Any one recommend a bleed kit?
    Northampton, UK
    Default Any one recommend a bleed kit?
    Hi guys, just looking to get my GSI Brake kit fitted, but I'm obviously going to have to bleed and replace the fluid once fitted...
    Was looking at a few on Ebay -
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_500wt_956
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_1536wt_1167
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_2412wt_1167
    Anyone have any better suggestions and / or tips - Other than the obvious, get someone else to do it LOL
    Regular Member Jezzy's Avatar
    S.E
    I've used the Eezibleed kit - works great, but it's about that same price in Halfords I think, so save yourself the postage cost (and delay) and get it there instead.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I use this too
    Gunson easibleed, about 16 squid from Halfords. Job done...
    May 2007
    south ockendon
    when using the easibleed kits just make sure it seals properly, especially if using a universal fitting cap
    i have seen loads of them that have leaked and a couple that have had the pipes split and leak
    Sep 2009
    Swindon
    I can confirm the eazibleed has a cap that does fit the Vectra no problem. Make sure you test it without any fluid the first time you use it, as two of the caps are similer sizes and one of them will just blow off under pressure.
    Frenchman
    I’ve had limited success with a Stanley Knife hth .............. ...................
    Oct 2007
    Shropshire
    ezzi bleed kit is very good and does fit my vectra unlike some others, though this one is cheaper;
    http://cgi.ebay.co.uk/EEZI-BLEED-BRA...item45eeff73f6
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    When I bought my big brake kit off Penfold101 he blead the brakes for me using the ezibleed and it was done in no time so I would deffo go for that kit, which reminds me that I need this kit also
    Quote Originally Posted by ANDY W View Post
    Had my car on 4 axle stands to change all discs and pads, went round the car twice in 5 minutes...
  1. How to Bleed Radiator
    By Sharkman in forum Engine & Drivetrain
    Last Post: 31st July 2012, 11:54
  2. How to bleed 2.0dti
    By piker john in forum Engine & Drivetrain
    Last Post: 26th May 2011, 18:49
  3. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
  4. bleed valve?
    By madman in forum Diesel Engine related
    Last Post: 11th May 2009, 22:40
  5. How DO you bleed a diesel
    By craigbarlow18 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2008, 08:04
