Thread: Cruise control doesn't work!
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default Cruise control doesn't work!
    Recently discovered my cruise control does not work anymore, the green light comes up when I press the button, but it doesn't activate! Had a crash in august, (car still hasn't been repaired!) in which I had my cruise contorl on, ever since then, it's not working. FTR, I try to activate it with speeds over 40 MPH like it says in the manual. Any ideas?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    sorry not heard of that thought if the light was on it should be on might be worth getting a vx dealer to have a look. otherwise you might be fitting parts you don't need
    Sep 2009
    Warrington
    Sorry, kind of bad explanation, it comes on when the button is pressed/held, but doesn't stay on!
    Regular Member andyman201's Avatar
    Middlesbrough
    Quote Originally Posted by Danialj32 View Post
    Try putting your foot under the clutch pedal to keep it up and press the button then see if it stays on cos a mate had that problem and it was the spring on the clutch
    Sep 2009
    Warrington
    Quote Originally Posted by andyman201 View Post
    Should the clutch go down when I press the cruise control button? I've been pressing the button driving at speeds of 70mph in 5th gear with the clutch up, and when pressing the speed just goes down.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no, put ur foot under the clutch padal and lift it back towards you then try the cruise as their is a small clutch switch at the top that needs to be engaged.
    Sep 2009
    Warrington
    Quote Originally Posted by mattv6diesel View Post
    Oh right, I see! I'll give it ago tomorrow on the way to work, and report straight back here Thanks for the responses!
  1. Cruise control.
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 20:02
  2. Cruise Control... How do you work it?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2011, 23:56
  3. Cruise control doesn't work!
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 20:56
  4. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
