Results 1 to 10 of 11
Thread: totating rear brake pistons but not going in - HELP!
    Glasgow
    Default totating rear brake pistons but not going in - HELP!
    Hi All
    Trying to replace my rear pads but when I am turning the rear pistons to retract them, nothing is happening, they just turn. When I turn them anti-clockwise they come out but will not go back in when I am turning them clockwise.
    Can you help? I have been placing no pressure and light pressure on the piston but no difference.
    cheers
    David
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i had the sme prob mate have you go the prpoper tool to wind them bak try quite a bit of pressure pal
    Glasgow
    I have a set of thin nose pliers. The piston is turning but just not going in. Do I need to use a lot of pressure? Dont want to risk damaging them
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    i had to use quite a bit of pressure mate to be honest and it makes life a bit easyer if you had the special tool for it you need to rotate clockwise
    Glasgow
    cheers Paul
    Went back out and put a bit more pressure in the piston and it has gone back in. Didnt fancy paying over £35 for the tool!! Was planning to fit new discs but dont have the special tool to get the caliper mounting bracket off to allow me to take the disc off so its just getting new pads
    cheers
    david
    Glasgow
    just took out the new pads and you wont believe it. Vauxhall have given me the wrong ones!!! AARRGGHH!!!!
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    glad you got it bak in pal i carnt belive the pads they are usless i would ring them up and get them told mate
    Oct 2007
    Shropshire
    I put preasure on with a g-clamp like you do for the fronts and twist the piston with molegrips. They have to be pressed in as you rotate. You can destroy them easily if you just rotate or push them......
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by circushead View Post
    Are you sure they're the wrong ones? Vx changed the design of the clips on them - you may have the old ones on your car and been sold the newer, better ones.
    May 2008
    Tyneside
    Here's the link showing old/new design. http://www.vectra-c.com/forum/showth...ight=rear+pads I had a great deal of trouble getting the piston back in but eventually suceeded. After driving for a while the wheel got hot and found the caliper had seized.
  1. Caliper pistons - which tool ?
    By Sparky67 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2016, 02:11
  2. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  3. Pistons
    By GCusdin in forum Petrol Engine related
    Last Post: 21st May 2012, 12:29
  4. Pistons need changing if Valves have hit!?!?!
    By Coupe2T in forum Engine & Drivetrain
    Last Post: 5th September 2011, 11:57
  5. Rear brake pad help please !!
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2010, 17:46
is vectra rear brake piston anti clockwise
