Thread: Power steering rack leakage
    Jun 2009
    Newark-on-Trent
    Question Power steering rack leakage
    When I thought I got everything sorted in my Vecy, new problem appeared. Just wandered how many of you suffer power steering rack failure?
    Mine is 2.2DTI Elegance.
    Oct 2009
    Great Yarmouth
    Have had and I think I still very slightly have on full lock a leack on the steering rack
    Took it to my loacl garage guy and he told me best part of £300 for a reconditioned one.
    However for £7 he bought a liquid that you put into the fluid that thicken up the break fliud and sels minor holes.
    Got me througha MOT Not sure what its called by it states that it works in 99% of racks. Ask in a wilco or similar.
    Hope this helps, any good with faulty horns please see my thread as I'm stuck. Cheers
    London
    i had the same last year
    dont buy any liquid it wont help and on top of it you can kill a pump
    try to get reconditioned or find vauxhall scrapyard and get one second hand with low millage cost me 250 fitted.
    cheers
    Aug 2009
    Eastleigh
    Hi, had a leak from my vec B a few yers ago, fluid was dripping from the rack. My local friendly mechanic syphoned out about half of the fluid from the reservoir and added a tin of Wynn's Automatic Transmission and Power Steering Stop Leak and Conditioner. Leak stopped almost immediately and drove for 2 years without losing a drop. Brill stuff - saved me a lot of dosh!
    Jun 2009
    Newark-on-Trent
    I was affraid to add any of these stop leak fluids, not sure whether it would have worked on Vectra C.
    I've replaced mine now with reconditioned one. Leak sorted and there was slight play which has dissapeared now. Overall it handles better.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    [Ex]Admin Duncan's Avatar
    I had to replace mine with a reconditioned rack a little while back due to leaking - common issue on these cars unfortunately.
  1. Power steering rack leaking
    By fuzzbomUK in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2010, 15:13
  2. power steering rack
    By steebdon in forum Handling & Braking
    Last Post: 21st January 2010, 16:14
  3. power steering pump..and rack..do they have to be from a 3.2
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 19:48
  4. Power Steering Rack
    By Matt21385 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2006, 13:24
vectra c steering rack leak
2007 vectra leaks in power steering system
vectra steering rack leaking fluid
can you use rack leak stop on vectra c
steering rack vectra c use stop leak
vectra c steering rack leaking
can i use power steering stop leak on my vectra
how to use Wynns Automatic Transmission & Power Steering Stop Leak
vectra c steering rack replacement
vectra steering rack stop leak
vectra c steering rack stop leak
vauxhall vectra power steering rack leaking reconditioned
