Results 1 to 10 of 23
Thread: Signum 3.0 cdti wont start
    Oct 2007
    Liverpool
    Default Signum 3.0 cdti wont start
    Long story short, the car was running perfect , went for a meal came out to go home and the car will not start.
    Loads of life in the battery, my brother who used to be a mec put some easy start in the air intake and it started to run but then stopped.
    Looked in the fuel filter , its empty.
    The car has loads of fuel in it.
    Any ideas guys ?? fuel pump ?
    Thanks for any help.
    Tank pump, or fuse for tank pump. If you get in a quiet area, and turn on the ignition, you should hear the pump pressurising the system. This is when it would fill up the filter. If you're really brave, you can take off one of the pipes going on to it to see if anything reaching the filter at all...
    Other possibilities if the pump IS running include a blockage in the tank, or depending on which way the fuel goes into the filter the filter itself may be blocked...
    Quote Originally Posted by Gumball 3000 View Post
    .Looked in the fuel filter , its empty
    There should be fuel in the fuel filter, so that suggests the issue lies between the input fuel lines and fuel tank
    However the fuel pump may not be drawing fuel either
    Reprime the fuel system and see what happens
    Quote Originally Posted by Penfold101 View Post
    fuse for tank pump
    The 3.0 v6 CDTI doesn't have a fuel pump in the fuel tank
    Instead there are two fuel pumps on the engine
    Oct 2007
    Liverpool
    How is that done ?
    Oct 2007
    Liverpool
    **UPDATE**
    Went to get it this morning with a tow truck.
    Went to start the car and it started 1st time !!!
    Only ran for about 10 - 15 secs tho, then stopped again.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I thought mine wasn't going to start today.
    Waiting for a reply from autovaux for the SCV kit.
    Oct 2007
    Liverpool
    Called in the garage today.
    They said machine said there was no fuel pressure, after the battery charger went on it it started no problem !!!
    Machine now says no problems ????
    Any ideas ?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    tank pump all cdti engines do, not as powerfull as a petrol but they do have them. i wouldn't be suprised if the relay was sticking (cheapest to start with) or pump its self was failing. peugeots used to have the same problem too 100k miles the car would die cause of the tank pump.
    Oct 2007
    Liverpool
    Quote Originally Posted by mattv6diesel View Post
    You know where the relay is ?
    I didnt get a handbook when i got the car.
    How much for the pump ???
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    don't know sorry possibly the rear fuse pannel. yours is the first i have heard
  1. Replies: 12
    Last Post: 25th May 2012, 19:54
  2. signum 2.2dti run out of diesel now wont start ???
    By signum dti in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 19:44
  3. 3.0 cdti wont start
    By Evilyoda in forum Vectra C / Signum Troubleshooting
    Last Post: 7th December 2011, 19:09
  4. CDTI Engine wont start
    By dag1 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 20:11
  5. cdti 150 wont start, just in the morning
    By peadar in forum Diesel Engine related
    Last Post: 12th March 2010, 21:27
vectra 3.0 cdti will not start
vectra 3.0 v6 cdti wont start when hot
cdti 3.0 fuel pump
3.0 cdti start badly
vectra c 3.0 cdti wont start
vectra c 3.0 cdti fuel filter empty
vectra 3 cdti wont start
opel signum wont start
vauxhall vectra v6 cdti 2008 fuel pump problems
vectra cdti.hard to.start in.tank.fuel.pump
vauxhall 3.0 wont start
