Thread: Boost pressure problem - 3.0CDTI
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Boost pressure problem - 3.0CDTI
    Fiddled with my mate's OP-COM and as predicted there was a stored fault code for fuel pressure. Rail pressure - negative deviation. Probably already had the pump done in the past because otherwise the fault code would have been "fuel system - unknown error"...but that doesn't bother me.
    What worries me is the difference between Boost pressure command and actual Boost pressure.
    On idle:
    Boost pressure command: 110kPa
    Boost pressure: 94kPa
    The boost sensor is clean as is the EGR. Turbo sounds healthy and last time I checked there was no play in the shaft.
    Full Member
    Bristol
    Hello mate the op-com software will show faults that tech 2 does not. My car list a list to long to go through using op-com. If I put tech 2 on it it shows no faults. if I put my snap on scaner on it it shows no faults. The op- com software picks up any blip in voltage as tech 2 and snap on are made to ignore little blips.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Check Swirl Valve !
    CristianTM.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by sb1uk View Post
    Thanks for reassuring me that all is not so bad But is it a possibility that the difference beforementioned is a cause of sticking turbo vanes?
    Full Member
    Bristol
    My turbo had no play in shaft. But vains were sticking . Had it cleaned no car runs loke a dream.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    it might be low on idle cause of the intake vacume, as no turbo boost just the air vacume from the 6cyl fireing draging in air
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I need another job
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    sb1uk mate can you get your car plugged in OP-COM and check the boost pressure value on idle?
  1. boost pressure
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 6th March 2010, 14:47
  2. Boost pressure
    By Mark2.2 in forum Petrol Engine related
    Last Post: 23rd January 2010, 18:46
  3. Boost Pressure Problem
    By CristianTM in forum Engine & Drivetrain
    Last Post: 27th September 2009, 20:53
  4. Boost Pressure>?
    By Biddyy in forum Diesel Engine related
    Last Post: 5th April 2008, 02:35
