Thread: Swirl valve slow
    Sep 2009
    Glasgow
    Default Swirl valve slow
    Hi all just got the wife to start car while i had a look at the swirl valve, it slowly moved left 2 right and when she turned off the car is quickly moved right 2 left don't know if this is normal i was expecting it to move quickly l-r. and does it move while driving because i do feel it is sluggish before turbo kicks in then it rips your head off.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    It's normal. And if you accelerate it will go back from right to left. All this is normal.
    Sep 2009
    Glasgow
    but is it normal to be slow at moving l-r
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the swirl flaps are closely monitored so i wouldn't worry if their was any issue a warning would tell you.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Quote Originally Posted by nokiaman1978 View Post
    It depends on the acceleration. Put your wife to accelerate fast from idle to 2500-3000 rpm and have a look.
    Sep 2009
    Glasgow
    thanks for the info.
    Wales, UK
    Quote Originally Posted by Lao View Post
    Hang on tight though !!
    Sep 2009
    Glasgow
    ha good one was thinking the same when i read it.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    dont want to be the bearer of bad news,
    mine used to hesitate, then would let rip, eventually my swirl valve actuator gave up, i had to have a new inlet manifold and all the gubbins
  1. Swirl Valve bar has come off
    By coooky in forum Engine & Drivetrain
    Last Post: 27th January 2014, 11:57
  2. swirl valve rod
    By pha-q2 in forum Troubleshooting
    Last Post: 26th November 2012, 17:36
  3. Egr valve, swirl valve problems etc..
  4. swirl valve do you need to use them
    By chrisgettings in forum Engine & Drivetrain
    Last Post: 29th March 2009, 22:59
  5. swirl valve ?
    By keith101 in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 09:32
