Results 1 to 3 of 3
Thread: Gear Box Tourqe conv. issues
    Regular Member Ean's Avatar
    Suffolk
    Thumbs down Gear Box Tourqe conv. issues
    Our Veccy 2.2 auto has got some issues.
    We bought it 3 years back, not really use it that much, maybe 5000 miles a year.
    However....when you push your foot right past kick down, between the first gear change, there's a HUGE THUMP! and a burts of 500 revs!
    tonight, engine man. light came on, when you put your foot down again, seemed like nothing was happeneing?! like there was NO drive!
    Is this the gear box? or torque converter?
    Thats the best way I can describe it!
    Thanks,
    Ian.
    Regular Member poves's Avatar
    lancashire
    Could be either , first things first - check the atf fluid level in the box , if it's low it will play up .
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Not quite what you've got but, taken from VX TIS2000, field remedy 1747:
    "Delayed upshift ( approx. 3 - 5 sec.) during upshift from 2 to 3. The engine speed increases by 200-400 RPM"
    Cause: "Transmission-oil pressure varying during upshift from 2 to 3".
    Remedy: "In case of customer complaint reprogram TCM with Software as of TIS 2000 CD 52"
    I know this is 2nd to 3rd, but might be a starting point? HTH
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Second gear boost issues..
    By unknownbullet in forum Engine & Drivetrain
    Last Post: 26th February 2013, 19:39
  3. 4th gear issues
    By bret.c in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2010, 13:14
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. 03, 2.2 sxi Cat Conv fail or other issue at stake ?
    By tonycam in forum Engine & Drivetrain
    Last Post: 16th October 2008, 18:44
