Results 1 to 10 of 17
Thread: 2.2 petrol LS engine cuting out and emmissions fault light on!
    Regular Member affirmation's Avatar
    May 2008
    Pembs
    Default 2.2 petrol LS engine cuting out and emmissions fault light on!
    As teh thread says - took a trip to cardiff today (Bob the Builder concert! - im so Rock!!) and the engine just cut out wihtout warning, stuttering etc and teh eml light came on - couldnt start teh car back up again for about 30 - 60 seconds then started no problem - emmisions light still on but teh car repsonds fine - it did it a futher three times between the journey there and back. each time same thing - just stops then doesnt resatart for about up to 2 minutes then starts as if nothing happened!! no loss of performance etc otherwise.
    any suggestions - going in for a service soon but wnated a bit of a heads up if this is going to be a big bill job!!!
    Jul 2009
    lanark
    swirl flaps, egr, crank sensor...............
    get it tech2'd lol
    May 2008
    Pembs
    so a blank cheque for the stealers then?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Is it a hatchback?
    May 2008
    Pembs
    yeah hatchback - 52 plate done 69k miles
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Right it wont be the swirl flaps then as the Z22SE doesn't have any. It also rules out the HP fuel pump also because it doesnt have one, just a pump in the tank which very rarely fails. If its the EGR that can be fixed for £13 mate. £3 for the blanking plate and £10 for EGR cheater. First off get the EGR off and give it a right good clean so the valve can move. The 2.2 only monitors the movement of the valve not the gas flow.
    May 2008
    Pembs
    Well that sounds encouraging - I didnt understand a thing you just said but I like the figures you posted!!! lol Time to check out the how to section!! Thanks Rushy you been sorting me out a treat lately - fancy coming round to install the HIDs that arrived today!!!! lol
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    This is my EGR with a blanking plate fitted, its on the battery side of the lump.
    Take it off and give everything a right good clean.
    May 2008
    Pembs
    Awesome - thanks for that mate - gonna give that a good clean tomorrow - how does that make the engine cut out?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    It can put it into limp as if its stick the ECU throws a fit. There's no real big issues with the Z22SE except the chain and it isn't that as it would never start again. It might be the EGR mate, but its something that you can look at yourself for free.
  1. Signum 2.2 petrol engine fault
    By Onlyonemarty in forum Engine & Drivetrain
    Last Post: 2nd September 2012, 16:00
  2. Emmissions Light
    By IWC in forum Engine & Drivetrain
    Last Post: 21st January 2011, 13:57
  3. emmissions light on dashboard
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 17:57
  4. emmissions light
    By spooney in forum Petrol Engine related
    Last Post: 16th November 2008, 14:01
