Thread: Couple Of Questions You Could Help Me With??
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    Question Couple Of Questions You Could Help Me With??
    I have a registration bulb out, is there a how 2 on how to get the reg bulb out?? i searched it but nothing came up an do you kno the code for the bulb like there are h7's witch are headlight bulbs an 501's witch are sidelight bulbs??
    And does anyone know the code for the reverse light??
    Thanks in advance
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    You have a small plastic spring clip on the R/H side of the holder, push it back with a small flat screwdriver whilst pulling down slightly. It should then just pop out, the bulb is just a twist fit and not sure on th ID but its just a small push fit one.
    Hope this helps
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by Fireyfella View Post
    Hope this helps
    E2 CF 12V 5W Push Fit Bulb
    Jun 2009
    Liverpool
    Just looked for then an they look the same as a sidelight bulb?? would a sidelight bulb work if i just poped it in?? just tried to get the bulb out an i couldnt find the clip??
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    Yep should work fine, The holder is countersunk in the bumper and the clip is flush with this on R/H side of the holder. a small flat screwdriver just pushes up a little and then gentally leaver it towards the holder away from the bumper.
    it should then move down a little so you can then get your fingers on it and pull down and away, it has a locating section on the right to stop it from dropping out.
    Jun 2007
    York
    Engine : 1.9 CDTi
    Mileage : Plenty
    it should then move down a little so you can then get your fingers on it and pull down and away, it has a locating section on the LEFT to stop it from dropping out.
    LEFT sorry slip of the finger!!!!!!
    Jun 2009
    Liverpool
    slip of the finger my a*s haha but ill let you off seen as your being helpful, havent looked at it yet because its too dark gonaa take a look in the morning when its abit brighter an hopefully abit dryer
  1. A couple of questions.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 16:16
  2. Couple of questions
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 20:14
  3. couple of questions........
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 14:55
  4. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  5. Couple of questions
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 01:35
