Thread: Front OS indicator issue
    Jun 2009
    Default Front OS indicator issue
    Hello
    I am having a few problems with the lights on my 05 Signum Elegance.
    It started with the front OS Indicator not working which seems to cause the side repeater and rear indicator to flash twice as fast, if I give the front head light a little knock the indicator will come back on and everthing works fine untill you turn the ignition off and then back on then you are back to square on.
    I had a quick look under the bonnet and noticed that some of the plastic clips that hold the headlight in were broken so I have just been upto Eurocar parts and bought an entire new headlight to the tune of £141.45 (ouch!) but whilst on my way back I had to use my horn (some dizzy woman carved me up) and when I pressed the horn I got a message on the computer saying both parking lights had gone!?!? checked the parking lights once I got back and sure enough neither were working so gave the headlights a knock and hey presto the came on.
    Anyone ever experianced this sort of thing too? any ideas on a fix?
    WGAF#5
    you obviously have a poor connection somewhere in the lamp circuit - the bulb warning will come on prior to a bulb blowing as the circuit is monitored constantly
    best advice would be to fit your replacement broken headlight
    then check the connection on the opposite park light bulb - and maybe have a few spare bulbs to replace them with to be on the safe side
    regards
    Dez
    Jun 2009
    Thanks for the reply Dez
    Going to drop the front bumper off tonight and fit the new headlight, just got everything crossed that it sorts out the problem as it's MOT time next week.
    Jun 2009
    update: I fitted the new headlight last night and it all fine now (touch wood)
    Mileage : 000
    Yep. Bad connection, by the sound of it.
    WGAF#5
    good stuff - love it when a plan comes together
    Quote Originally Posted by CowFish View Post
    This is a standard feature on any car I've ever driven mate - tells you one of the bulbs isn't working...
  1. very weird issue with indicator
    By gregj in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2013, 19:05
  2. Bizarre indicator issue
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 16:40
  3. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 21:13
  4. Vectra break light and indicator issue
    By goooba769 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2012, 19:10
  5. Indicator issue.
    By ElSpoooel in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2010, 18:53
