Thread: Best NON permenant 12v live connections
    Northampton, UK
    Default Best NON permenant 12v live connections
    Hi guys, after a bit of advice, I'm looking to find, preferably 2x 12 volt lives somewhere in or around the dash area, (or anywhere inbetween the front seats and dash) that are only powered when the ignition is on, were I can wire into easily and wont damage the electrics or look stupid. I'm in NO way electrically minded... so be gentle! LOL
    Thanks in advance!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If you drop the glovebox out and look to the left you'll see the rear of the fusebox,there are loads of ignition lives in here,they'll be black and go for the largest gauge one you can find,this way you shoudn't upset anything.
    Cigarette lighter...
    Sep 2009
    Stratford-upon-Avon
    I use the cig lighter socket for everything, just pop out the ashtray and you will see the two wires going to it, splice into these, havent tried the glovebox mthod, but good to know!
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Heated seat live/earth connections
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 12:58
  3. Is the cig lighter Switch Live or Perm Live
    By jake.clay in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2011, 12:48
  4. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
