Thread: Rain censor
    Full Member
    Bristol
    Default Rain censor
    Filled new wiper motor and wiper linkage but the rain sensor does no work. Has anyone had this problem.
    Full Member
    Bristol
    Just to add new windscreen fitted as well.
    WGAF#5
    did they transfer the Gel part off of the old windscreen (sensor )when they fitted the new screen - if not then the gel part is missing and wont make a contact to allow the sensor to operate
    Full Member
    Bristol
    I will check in the morning but I think the winscreen cam with the sensor attached. Because they asked if I had a rain sensor screen.
    WGAF#5
    they ask if you have a rain sensor to ensure they order the correct type of screen the senor is separate to the screen itseld and is fitted to it
    if they removed the old screen there should have been a "jelly" that sandwiches between the screen and the sensor to make the two work
    if they didnt transfer it which they sometimes forget then the sensor will be useless
    Full Member
    Bristol
    ok deztroyer. thanks I will call my windscreen man in the morning to see if he did fit it. I use the same guy all the time so he will remember.
  1. lambada censor
    Last Post: 5th July 2010, 17:18
  2. need help!!! pad wear censor dash light
    By gokartin in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2010, 12:57
  3. brake pad wear censor
    Last Post: 10th June 2010, 20:05
  4. Boost censor
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:08
