Thread: DMF Replacement
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Default DMF Replacement
    Hi all
    My car is going in to Vauxhall tomorrow hopefully to have the dmf replaced under warranty(I get vibration/rumbling through the clutch pedal)
    The question is should I expect the clutch to be replaced as a matter of course???
    Obviously if they refuse to fit a new clutch, I will have to pay for a new clutch, as there will be little point putting the old one back, even though the car has only done approx 24000 miles
    Cheers Ian
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    They won't replace the clutch as a matter of replacing the DMF, they would only change it if it needed it - you probably would have to foot the bill of a clutch to get done, which is a highly recommended at DMF change time.
    May 2008
    Derbyshire (south)
    If the clutch is damaged because of the dmf fault it should be replaced, if they don't & the clutch goes after a short period after, i would contest it had failed & it negligence on their part.
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Thanks for the replys guys, pretty much what I thought, I'm probably going to have to shell out for the clutch, for peace of mind
    Cheers Ian
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Default Update!!!
    Quote Originally Posted by Ianz View Post
    Hi all
    Cheers Ian
    Result!!! Stevens Vauxhall (Crawley) have replaced the flywheel & CLUTCH under warranty, I should be able to collect car later today once they have finished putting it back together & test drove it, they also provided a free courtesy car so hats off to Stevens.
    Cheers Ian
    Regular Member Gerdo3's Avatar
    Blantyre
    sorry been v busy just seen your post
    well done, was going to say vx only warrant the clutch to 18k so you got a result & saved £329
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    well done fella
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    nice result and a big thumbs up to the garage (STEVENS)
  1. replacement key
    By jabba in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2012, 15:03
  2. Replacement GID - what to look for?
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 16:22
  3. DMF Replacement
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 14:01
  4. DMF replacement
    By silky in forum Engine & Drivetrain
    Last Post: 4th May 2009, 08:09
  5. Replacement for the Vec
    By AJA in forum General Chat
    Last Post: 23rd June 2006, 18:56
