Thread: cdti 150 slight misfire! help needed
    Oct 2009
    yorkshire
    Default cdti 150 slight misfire! help needed
    hi ive owned my vectra now for a year and over the past few month the car has been a little lumpy on startup for about 1-2 mins. i cleaned the egr valve yesterday no rust but was sooted up. i removed this but today when driving, at around 2-3k the car hesitates like its misfiring, but if i give it full throttle its fine just when driving between 2-3k.
    anyone have any ideas what to try/change. thanks in advance... craig
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    did you clean the hole where the egr bolts to manifold?, clean the boost sensor, is your swirl rod still connected, other than that have you had the 3rd injector wiring mod.
    Aug 2009
    sheffield
    as above- clean egr valve+ housing . clean boost sensor. clean 3rd injector wiring plug/or renew with up-grade plug. drop some injection cleaner in tank. and cross your fingers... look it all up in how 2. your not alone....
    Oct 2009
    yorkshire
    hi, thanks for the replys ive been under the bonnet and noticed ive got the injector mod on all the injectors and the inlet manifold looks fairly new to me, the rods are still connected so must be the egr valve going to strip it down again at work tomorrow to see if this is the problem thanks again
    Oct 2009
    yorkshire
    just a update ive stripped the egr valve down and found the spring was bent i straightened it cleaned the boost sensor gave a run seemed ok.
    soon as it got warm exacally same again.
    it looks like the injectors have the modified plugs so just looking for some advice on what to check next
    thanks...craig
    Reading
    Mine does the same, I've been told its because the swirl valves are shot, with up and down movement as well as rotational, easy way to check is to see if there is some black, wet, oily residue around the swirls. Got my car about a year ago with 143k on, and when I checked, the bar had come off, so I repaired it using the tap washers, in the last thousand miles, its started to play up, so I've bought an Inlet manifold and swirl valve actuator, and when I have a couple of clear days, I'll strip it all down, and fit the new one, along with the cambelt and waterpump.
    Good Luck with it, let me know if its not the swirls.
    Mark
    Oct 2009
    yorkshire
    hi mate i swapped the egr solonoid for one i got from a 120 in scrappers and its like new again.
    only thing i can think of is that ive damaged the egr when i cleaned it but thanks for the help everyone
    Regular Member Blagmeister's Avatar
    Warks
    I have this same problem and it can't be the swirl flaps as I had a new manifold earlier this year, together with a new throttle body [showing fault codes], turbo overhaul by TT [again more fault codes]. I cleaned the EGR when I first had the car, [albeit not the full solenoid stripdown] so I am hoping that an EGR swap might do the trick but the symptoms are identical to yours:
    Gentle acceleration causes a stutter at 2250-2500 rpm but hard acceleration gives no such problem.
    Fingers crossed.
  1. 3.2 GSi slight misfire, need help....
    By TimTay in forum Engine & Drivetrain
    Last Post: 19th August 2011, 11:10
  2. Slight misfire at idle
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:52
  3. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  4. 1.9 CDTi Slight misfire
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2010, 00:19
  5. Slight CDTI misfire
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 2nd June 2010, 17:46
