Results 1 to 10 of 14
Thread: VEC-B HELP, P0335 Crank Sensor-CAR WONT START
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default VEC-B HELP, P0335 Crank Sensor-CAR WONT START
    Hello chaps,
    My brothers car is playing up, its a 1.8 Vectra-B X18XE, it wont start, keeps turning and turning but wont start at all. It just doesnt fire. Plenty of Fuel.
    Have run the Op-Com on it and it has come up with P0335, which points to the crank sensor.
    So, will the Crank Sensor prevent the car starting?
    HELP PLEASE FOLKS.
    Thank you.
    p.s, Am I correct in thinking the crank sensor is by the cambelt right at the bottom?
    Thanks again.
    ________________
    Mileage : 000
    Yes it is. It is a bit awkward to get to. Best to cut the old lead, and route the new one the best you can.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    if you cut wire make sure its unplugged oe you will kiss goodbye to the ecu .
    Birmingham
    OK, an UPDATE. I got the car running. lets go back to the top, the engine is actually a X/Z18XE so its the "Z" engine, so my balls up.
    Basically, I went to turn it and it was turning but not firing. So I cleared all the codes and disconnected the Crank Sensor (simply unplugged it) and I turned it over and it burst into life.
    The car allowed me to rev it but it was in Limp Mode so wouldnt rev over 4k rpm. When I released the throttle, it simply cut out.
    Re-started again with the sensor connected and once again, didnt start.
    With the Sensor connected, im getting the code: "P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction".
    When I disconnect the Sensor im getting the above code AND: P0335 Crankshaft Sensor Open Circuit (similar, basically saying circuit open).
    So guy's, what could it possible be?
    Someone says to me its the ECU playing game,s BUT im not convinced, I am a Vaux-Man after all.
    So please, come out of the woodwork and help me out please.
    Thanks, G.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    crank sensor is shot by the sound of it .......
    Birmingham
    We have had a BRAND NEW one in it, and I have replaced with the OLD one as well.
    Could a new one me scrooged too with the same problem?
    Feb 2006
    dudley
    sorry didnt read you had a new one in .......if you have had a new one and it is still the same with the same code .....you need to check the wires from the sensor to the ecu and if there ok your next step is a ecu .....make shure the wires havent rubbed together they would give you good resistance but confuse the ecu ......the other code means the bulb in the dash is blown / missing ....
    Birmingham
    Birmingham
    BUT, What has the crank sensor got to do with all of this?
    BEFORE, I was getting a crank sensor error, now thats no present SINCE I cleared the codes!!!
    Feb 2006
    dudley
    sorry mate you have lost me now ..... has the crank sensor code now gone ? .
  1. Crank Sensor
    By GCusdin in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:13
  2. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  3. 1.9cdti engine wont crank or turn over
    By Turbomanrony in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2012, 11:01
  4. P0340 - could it be crank sensor?
    By rich r in forum Engine & Drivetrain
    Last Post: 25th December 2011, 19:00
  5. p0335 crankshaft sensor open circuit
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 28th July 2010, 11:52
Opel P0335-000
Vauxhall DTC P0335-29
po335 crankshaft position sensor a circuit a vectra c 19 tdcin
https:www.vectra-c.comforumshowthread.php94178-VEC-B-HELP-P0335-Crank-Sensor-CAR-WONT-START
vectra b 1.8 po335
zafira b crank sensor circuit
zafira b code p0335
vectra 3.2v6 starting problems crank position sensor
Opel DTC P0335-28
Po335 vectra c
signum cdti 150 p0335
p0335 vauxhall vectra
p0335 vectra c
p0335 vectra c 1.9 tdci
vectra c 1.9 po335
z18xe had new crankshaft sensor now it wont start why is that
vectra 1.9 cdti wont start crankshaft sensor
