Thread: 'check safeguard' and alarm keeps going off!
    Sep 2009
    Sleaford
    Default 'check safeguard' and alarm keeps going off!
    Hi all, about 3 weeks ago i removed the standard cd head unit from my vectra and fitted my alpine. a week and a half later the alarm sounds and keeps going off every time i reset it (with the key fob) also throughout the night!!!. recently 'check safeguard' has appeared on the dash display on ignition. i dont know if the head unit removal has anything to do with the alarm going off but would like to avoid a dealership for diagnostics especially if its something simple. any ideas???
    cheers
    As yours is an estate its fairly common for the alarm connections to the rear windows to become damaged thus setting the alarm off.
    Really imo the best way to narrow it down is to get the codes read to narrow down the fault area
    Anyone else?
    Sep 2009
    Sleaford
    i've checked the rear windows and the tracks seem intact. i'll have a look at the motion sensors on the maplight, failing that then tech 2 is calling. anyone know what sort of price i'm looking at for the diagnostics?
    cheers
    Normally half hours labour to just read the codes, they normally come up with some crap to charge you more though.
    WGAF#5
    have you attempted to set the alarm with the ultrasonics disabled- did the alarm still go off???
    and what voltage is your battery showing if you meter it under and off load...just wondering if you have an "excessive" amp draw from your new head unit ?? what did you take the live feed from ?
    regards
    Dez
    Blantyre
    Think Plasma had this issue a while back, turned out to be a fuse if i remember correctly !
    Regular Member JamesGTB's Avatar
    Jul 2009
    Check fuse 23 in the rear boot compartment where the first aid box should be.
    I have removed mine due to the alarm going off all the time and i get this message everytime i start the car so maybe your fuse has blown.
    Sep 2009
    Sleaford
    i've checked fuse 23 and its ok, but tried the central locking with the fuse out and hey-presto! no alarm and no 'check safeguard'! must be a track on the windows have gone O/C. had a look and cant see anything broken, does anyone know where the connectors are for the tracks on the window alarm?
    cheers
    Reading
    Had the broken track on one of my windows, just unplugged the loom, and bridged the terminals with about an inch of wire with a spade connector crimped to each end, had no trouble for months now.
  1. Safeguard Check!
    Last Post: 14th January 2014, 00:27
  2. Safeguard check
    By VikingLammy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 21:39
  3. Safeguard message and no alarm
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 21:44
  4. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  5. Check Safeguard
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 10:25
