Results 1 to 10 of 14
Thread: 3.0 cdti v6 pre facelift
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    Default 3.0 cdti v6 pre facelift
    Hi all,
    just a quick one.
    My dad is looking at a 3.0 v6 cdti pre-facelift 2005 auto estate and is wondering what the major pro's and con's are?
    Any real bad things about this motor? any reason why we shouldn't touch it with a barge pole?
    cheers all, Tom
    Rubbin'z racing Harry!
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    My V6 CDTI Auto was perfect until it turned 100,000 miles, then it started smoking heavily and became very expensive.
    My advice would be to find one with low mileage and a good service history.
    Other than that they are great, the V6 CDTI is very good with the auto box.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    not i know of had a sri for two years never with a problem but mine was a manual so can't help with gearbox reliability sorry. easily got 40 + on a run but a little thursty round town but when you drive and hear it you wont care. cause of the drag from very low revs are great to drive. why i got another in facelift form.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Great motor, but as said VERY expensive if it goes wrong. I just chucked away nearly £2000 for repairs and maintenance...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the 19 cdti aren't trouble free either and can cost alot of money if you buy a problem one. just take it for a long road test and drive it hard and soft and try every button, i wouldn't have any other engine under a vectra
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Fuel pump on mine has started to play tricks.
    More money to the dealer for parts...YAY
    As above
    You have the usual Vectra niggles; electrical, suspension, air con, etc
    However the engine is virtually bomb proof, compared to other GM group engines (all my previous ones have got to 70K miles and suffered permanent faults that could never be fixed)
    Servicing should be 2 years / 30K miles, but the service indicator rarely goes past 20K miles
    Servicing is little more than an oil and filter change, visual inspection
    You can stick with the GM oil or if out of warranty go for any synthetic oil
    The cambelt can easily be left to 100K miles, but it will cost you the best part of £500
    The only other major concern is at 4 or 5 years old (doesn't seem to be mileage lead) when the SCVs may become blocked
    This is a 10 hour job, typical quotes for cost is £900 to £1500
    My dealership managed it in just under 9 hours at a cost of £850
    However now that it has been done once it should be cheaper next time as the EMS update won't be required, and they have experience of it as well
    Equally, if carried out at the same time as the cambelt change then it should almost half the labour cost of the entire job
    The SCV itself costs about £200
    Sadly the brake pads are over priced, at £150 fitted
    So look at brake pad and disc kits
    Fitted they are just under £200
    Tyres will last about 10K miles per axle, swapped rear to front as they wear
    Make sure you use XL rated tyres AND buy the best you can afford
    Regular Member robster23's Avatar
    Hastings
    Not a bad motor - just got my cambelt done for £300 including tensioners (Genuine VX parts).
    Auto box can sometimes make funny choices but it's a great cruiser. Also has tiptronic style selection on the box.
    The V6 burble keeps a smile on your face.
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    cheers for all info everyone.
    Think dad is off to check the motor out tomorow. Thanks all
    Full Member
    Bristol
    I love mine. I will buy a newer one. So smooth to drive. more reliable than 1.9 engine vectra's.
  1. facelift cdti
    By SRIcdti205 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2011, 22:08
  2. 07 Facelift CDTI
    By adam_starkie in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 22:22
  3. Pre-facelift or facelift vectra V6 CDTi?
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2009, 05:34
  4. Facelift 3.0 V6 SRi CDTi
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2009, 23:02
  5. Pre-Facelift 3.0 V6 CDTi
    By pwjolly in forum Diesel Engine related
    Last Post: 6th October 2007, 09:06
