Thread: richbrook door pins
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    Default richbrook door pins
    just bought and fittedc the vauxhall richbrook door pins from red griffin styling (good service by the way) and upon fitting them i found that three of them went on fine but the rear drivers side lock pin seems to have a bend in it which stops the new pin slipping into position. has anyone else had this problem as it looks like ill have to cut about half an inch off the new pin so that it sights properly! also fitted the bee sting aerial kindly supplied by mr ed taylor and have to say it looks the dogs danglies thanks again ed!
    On a Sabbatical NRGuk's Avatar
    May 2006
    barnsley
    how much ???? i know sum have had to run a drill down them as thir was bit,s of plastic still in the hole stopping the rod seating right
    Feb 2006
    Vehicle : Vauxhall
    Engine : 2.0 turbo
    Quote Originally Posted by NRGuk
    no ive looked in to the door panel and there is a bend in the rod which seems to stop the pin sliding down and the only way i can see it fitting is to cut the pin as the cantre of gthe pin is clear of obstructions
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    if i were you mate i would take the door card off and try and straighten the rod
    Nr Cardiff
    Ditto
    Jan 2006
    Skynet HQ EMEC#5
    I also found that about the rear door, after I had already fitted the front one.
    All I have done is make them all the same height as the rear. The grub screws tighten up correctly and the griffin logo sits just above the door card.
    When the door is locked, the top grub screw sits just under the surface of the door card.
  1. Chrome Richbrook door pins
    By Ben50n in forum Styling
    Last Post: 27th January 2012, 14:13
  2. For Sale: Richbrook door lock pins
    By chrisvectra in forum Parts for sale
    Last Post: 25th January 2012, 19:48
  3. richbrook door pins
    By dannydm1 in forum Styling
    Last Post: 23rd August 2011, 19:00
  4. Richbrook alloy door pins x 4
    By blues n twos in forum Parts for sale
    Last Post: 3rd August 2010, 20:34
  5. richbrook door pins
    By topgun in forum Styling
    Last Post: 21st August 2009, 22:28
door pin vectra c site:www.vectra-c.com
