Thread: How do you know when to change brake discs
    jilava
    Default How do you know when to change brake discs
    How deep can the wear marks be? I remember reading somewhere that at 3mm wear they should be changed?
    Regular Member Jezzy's Avatar
    S.E
    Each disk has a given minimum thickness stated by the disk manufacturer. Plus, if the disk has a lip on the edge, or is scored or grooved, then it will need changing even if it hasn't yet reached the minimum thickness.
    jilava
    well mine does have a lip on the edge but isn't this normal sign of wear? on stock vectra c disks what is this minimum thickness of the disc?
    Admin plasma's Avatar
    On the Forum
    324 Post(s)
    Engine : 150
    Mileage : 74000
    Just filed the lip down on mine and resurfaced the disk, should be a bit quiter now
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    I'd just change it anyway regardless mate - it's not that much extra and you probably wouldn't have to do it again while you owned the car...
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    thickness new 25 mm,minimum thickness 22mm with 57mm piston diamiter/28mm new ,minimum 25mm with 60mm piston (front vented discs)
    rear, solid discs new 12mm,minimum 10mm with 38mm piston/rear ventilated discs new 20mm ,minimum 18mm with 38mm piston
    jilava
    thanks guys, jonny that was exactly what I asked for! thank you
  1. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. Want to change brake pads and discs
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 17:53
