Thread: Squeeky and crunchy braking noise
    Default Squeeky and crunchy braking noise
    I noticed this a few weeks ago
    Once the car has been driven for a few miles and has warmed up, I do NOT get this when the car is cold
    Apply the footbrake and I can hear a squeky and crunchy noise from the front of the car
    It is so loud it can be heard over the engine and gets funny looks when I apply the brakes!
    The footbrake keeps going as well
    If I apply it progressively (which is something I don't normally do) then it keeps going to the floor!
    I suspect the brake master cylinder is the cause, but I have not noticed any loss in braking efficiency
    I normally only use the brakes very lightly or for small sharp applications, virtually never for high speed emergency applications
    As per the warranty, I don't think this is yet covered as a part has not yet failed
    However the noise clearly means something is wrong, or near to going wrong!
    Perhaps I could bend the truth and book the car in for occasional loss of braking
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi M
    if your pedel is traveling to the floor then a part has failed.driving the car in this condition is very dangerous as total failure may involve you in a very serious accident. also if you have an accident and your insurance company find out about your problem your insurance is void,get the car in to the garage before you kill someone
    WGAF#5
    any maufacturer/garage/driver should treat any braking issue as a matter of saftey
    your local garage/warranty company should be happy enough to put the vehicle on rollers and test the braking efficiency and see if there is any creep on the pedal
    if the efficiency shows weak or pedal creep is present ...then as suspected master or even slave cylinder may be on the way out or leaking internally
    - and the warranty company may even agree (if sold to them correctly by the repairing garage) that prevention is better than awaiting the more expensive "cure" of a front end rebuild owing to catasrophic failure of the brakes
    regards
    Dez
    The car was inspected the following morning
    Dealership performed a visual inspection and then a brake efficiency test, and found all was working correctly, but did agree there was an unusual noise from the offside caliper when the brakes were hot
    Network Q refused the claim as there were no worn or failed parts
    I then booked the car in for 06 November
    If the claim was refused then I was prepared to pay for two new front calipers
    As it was the following day the clutch went
    The offside caliper was removed and inspected
    It was deemed to be sufficiently worn and the claim was approved
    Sadly they didn't inform of this at any stage, there are even notes on the papework that I would pay so that both front calipers were replaced together
    I will therefore need to book the car back in for this (nearside caliper)
    The quote is £210, fully fitted
  1. squelching noise when braking
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 23:43
  2. crunching noise under braking
    By drspamuk in forum Handling & Braking
    Last Post: 3rd October 2010, 16:50
  3. Noise when braking
    By richje100 in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2010, 17:16
  4. Squeeky noise that goes as soon as I raise the revs a bit
    By ishaqmir in forum Engine & Drivetrain
    Last Post: 28th June 2009, 12:06
  5. Knocking noise when braking?
    By karlp606 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 12:29
