Thread: Heater trouble goes on !!! Vectra C
    Oct 2009
    UK
    Default Heater trouble goes on !!! Vectra C
    Hi I have read all the posts on this thread and have followed the various solutions/ideas hoping that this time it will work.........Basically I have a similar problem as most my heater/blower only works on setting 4. The bottom blue relay clicks as the dial is turned from off to 1 but nothing happens until the dial is at position 4, when the brown top relay clicks and the heater blows full blast. I have changed both relays, put in another resisitor pack, fitted a new 240c fuse (69p from Maplins) to the original resistor pack eventhough it tested okay. I have even removed the heater unit and tested the fan spins freely but I still have off or full, nothing in between.
    Does anyone have any other ideas????? Much appreciated.
    Cheers.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    work as a tech at vauxhall. we have fitted loads of heater motor resistors. the reason 4 works is cause when you remove it you would see its a sraight circuit the others are resisted to change the fan speed or can you borrow some ones heater switch face no programing needed just plug and play.
    Oct 2009
    UK
    Default Cheers
    I take it from that you are suggesting the dial is at fault. We had eventually come to that conclusion after a process of illimination and realised that 4 was direct to the heater at full power but it's always best to ask. Is it easy to remove the offending dial and repair or does the full face plate have to be changed?
    Thanks.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I have a PCB heater board here very easy to change,mine is the normal one with no ECC out of a 2003 car
    Irmscher Insignia CDTI 130
    Oct 2009
    UK
    Hi where is the pcb for the heater and if you think this is the problem how much do you want for the pcb.
    Cheers.
  1. help with trouble codes on a vectra 2.2 dti
    By deano1 in forum Engine & Drivetrain
    Last Post: 6th September 2012, 20:08
  2. 04 Vectra 1.9 DTI Starting trouble
    By swankytech in forum Engine & Drivetrain
    Last Post: 30th December 2011, 12:10
  3. Having trouble selling my Vectra?
    By urbanfox in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 19:00
  4. Vectra-B TROUBLE CODES
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 16th May 2009, 19:21
  5. vectra trouble again!!!!!
    By wayne in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2008, 08:29
