Results 1 to 10 of 13
Thread: Front end face lift on pre facelift
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Front end face lift on pre facelift
    Has anyone done this? what is involved? wings, bumper, bonnet, lights?
    Does the slam panel need changed over and are the wiring connectors the same?
    Northampton, UK
    Theres a few of us that have done it. Not really much to it. Bumper, bonnet, wings, bumper guides, new bonnet stay, headlamps etc...
    The front panel doesnt need to be changed, just new holes for the headlamp mounts I believe. But when I did mine, I did change the panel.
    Jan 2008
    Dundee
    Quote Originally Posted by n_hudson View Post
    Is the front panel bolted or welded?
    Whats the bonnet stay? gas strut?
    Northampton, UK
    The gas strut went on the facelift, the bonnet is aluminium and bends with the gas strut, so it went back to a manual stick in the hole job. The front panel is spot welded in I think about 8-10 places, just drill them out. There are the bolt mounts too, cant remember how many. You'll also need new bumper guides and 2x L shaped mounts that attach to the new front panel to mount the bottom of the facelift headlamps.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    I have done this too mate, like n_hudson said you can re-use the prefacelift front panel all you will need to do is drill holes for the grille and headlamps, front panel is held on with bolts and a few spot welds
    Jan 2008
    Dundee
    I'll probably just used my orginal front panel if thats the case. Will i still need new bumper mounts or will the new bumper fit straight on?
    Northampton, UK
    The bumper guides are totally different they "pull" the bumper in to lock it in place at the sides, under the wheel arch. They are also curved and are held on with rivets.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If decide to do this and want a hand bud just shout, I have a spot welder etc. and also if your current front end is in good condition i'd poss buy it from you (mine is badly stone chipped)
    Jan 2008
    Dundee
    so these are new guides to fit onto the new wings yes? What about the front crash bar? is there anything needed there?
    Northampton, UK
    Check out my "Back to Prefacelift" thread for pics and how easy it is.
    http://www.vectra-c.com/forum/showth...ght=facelifted
  1. Pre Facelift- Face Lift
    By IanIOM in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2012, 22:13
  2. Face Lift SRi Front Fog Lights
    By Paul_NI in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2012, 12:53
  3. facelift and pre face lift rear bumpers
    By coldo in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2011, 21:38
  4. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  5. Can you fit the Bonet springs from a pre face lift to a facelift
    By stugga in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2009, 22:17
Can you fit a pre facelift front end to a facelifted vauxhall vectra c
will facelift fit pre facelift vectra
vectra c facelift site:www.vectra-c.com
how to facelift a vectra c
