Results 1 to 10 of 13
Thread: vectra c 2007 power steering pump..
    Regular Member robwilson69's Avatar
    Oct 2009
    essex
    Default vectra c 2007 power steering pump..
    Hi all i need to change my power steering pump and was told by vaux they are coded to the car is this true, can i not just swap with another one? has anyone done this before?
    I can imagine that this is true as its a main electricial part of the car.
    Oct 2009
    essex
    thanks, but can anyone confirm 100%
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    when electro-hydraulic supply unit is replaced control unit has to be reprogramed using TECH 2
    Oct 2009
    essex
    ok thanks is the tech 2 capable of programming a second hand unit? i was told they need the old unit to read and program only a new unit?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i have replaced mine twice and never needed to be tech 2,
    Oct 2009
    essex
    You mean just a swap over with a second hand unit? was thinking it maybe cuz mine is 2007 model?
    Quote Originally Posted by robwilson69 View Post
    straight swap m8, but there are 2 types of pumps, 1 with a level sensor and one with out, i have just fitted 1 with a level sensor but i dont have it in the loom, and i have no problems with it what so ever, i have pics of what they look like inside too
    Jul 2009
    Engine : 20 Dti
    be carefullllllllllllllllllllllllllllllllllllllllllll llll
    Jul 2009
    lanark
    the ones mounted on top of the rack deffo need programmed mate,
    second hand ones need reset on the donor car,
    you also need to reset and reprogramme your cim, to clear the little power steering light that will appear
    i work for a dealer and know 100% bud, do it every day
  1. Vectra C power steering pump replacement
    By paulhea in forum General Motoring Chat
    Last Post: 17th September 2012, 13:59
