Results 1 to 10 of 15
Thread: timing belt
    Regular Member bobobaldy's Avatar
    Oct 2009
    lanarkshire
    Default timing belt
    I'm going to get my timing belt and water pump replaced in the next few weeks .Has anybody bought the kit recently and if so how much for it and the pump and where did you get it from.?I have seen the kit on ebay for £95 and the pump for £45.I have asked my local garage how much to fit and he said £60 does this sound ok.?
    Northampton, UK
    For my 2.0T it came to £332 for the water pump, belt and fitting at the dealer.
    Sep 2009
    Swindon
    I have just purchased both the timing belt kit and the water pump from Vaux main dealer in Swindon, the cam belt kit was £101 and the water pump was 49.30. all including the VAT, going to fit it myself.
    The guy told me that the sealant for the water pump came with it, but upon opening the box it clearly doesn't .............. something else to buy.
    I would get a genuine one from Vauxhall being such a critical part
    Frenchman
    Oct 2009
    lanarkshire
    Forgot to mention its a 1.9 cdti sri 2007 model.
    Regular Member Grahamy's Avatar
    Ryton
    Sorry but i thought the 1.9 cdti had a timing chain,
    and being a 2007 model it should not need changing
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Wink timing belt
    I had my inlet manifold and control unit changed and my local garage said lets change the timing belt i had it done it was the full kit and he told me it cost 81 pounds i had all this done for 600 pounds i hope this helps
    inlet manifold was £190
    control unit was £123
    timing kit was £81
    Oct 2009
    lanarkshire
    Ohh dont know now.The cars done over 70000 so was advised to get it done sooner rather than later.?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by frenchman View Post
    Frenchman
    you dont need sealent for the water pump as it comes with its own seal
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by Grahamy View Post
    the 1.9 cdti has a belt and should be changed at 100k
    Oct 2009
    South Yorkshire
    Default timing belt
    Yes the sri does have a belt and old dti engine had chains but the cdti has a belt but you change it about 100k i only changed it because of the manifold fault
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
