Thread: Help!!! Vectra C 1.8 SRI
    Oct 2009
    hull
    Default Help!!! Vectra C 1.8 SRI
    Posted: Thu Oct 22, 2009 8:51 pm Post subject: HELP! vectra C (SRI) just wondered if any 1 knew what was wrong with my Vectra C the problem is when i change gear my rev count climbs so it makes my gear change feel really lumpy
    (THANKS)
    dazuk
    Jun 2009
    doncaster
    my 1.8 tends to over rev at gear change when its approaching the redline,i think its something to do with the engine management,dont know why it does it- it just does!,if i get too throttle happy the gears wont select and i have to drop the revs again to select gears,is that whats happening to you?
    Oct 2007
    Shropshire
    Mine did that, the throttle (electronic) was sticking. In the air intake their is a flap controlled by a motor, take it off and spend ages doing the following ritual. Spray WD40 on it then work the flap, open then closed. repeat until it works!!!
    VX quoted me 160 for a new one.
    I TAKE NO RESPONCIBILTY IF YOU BREAK IT!!
    Oct 2009
    hull
    No it revs up in every gear at low revs when you clutch down revs clime 5 to 600 rpm's giving the feeling like you have missed clutched or you have not dethrotled any ideas.
    Mileage : 000
    I am not too familiar with the 1.8 engine on the Vectra C. But if it is simalar to the Vecta B. If it has an Air Control Valve on the side of the throttle body. That might be sticking. On the B you can spray carb cleaner into the Two small holes inside the top of the throttle body, this cleans out any "gunge" that might be holding the piston from moving as it should. As I say I am not too familiar with the Vec C 1.8. But it might be something you could try. If there is an Air Valve on the side of the throttle body.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
