Thread: cold start only, spanner light?
    VIP-Member MCD's Avatar
    Romiley
    9 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP Saphirre Black
    Engine : 2.0 16v Turbo
    Mileage : 60k
    Default cold start only, spanner light?
    Any ideas chaps?
    Only happens in morning, or at the end of a day at work, never after a few hours or anything. Start car, the light wont go out. Turn ignition off, then restart, goes out. Car is performing fine, fuel economy not dropped, all perfect... just annyoing as past few days basically had to start it twice to get the light off! And yes, starts fine everytime?
    Go it booked in for Tech II this evening, but just wondered if anyone had a heads up on this first?
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP NAV - PLUS SUNROOF!
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    what engine?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Grimo72 View Post
    what engine?
    CDTi 150.
    Sorry I can't help, but good to see you again, and the Tech II should tell you what it is, probably a faulty sensor.
    It could be worth checking the glow plugs, maybe one or more not working. I had this with my cdti.
    West
    Most likely to be the glow plugs or a pre heater fault somewhere... with the dti's on the older vec's the light used to go out without restarting when the engine had a little heat.
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Had this problem with my dti, it was the glowplug relay & its a lot less smokey! Big dif in starting.
  1. Spanner Light Cold Start
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 17th April 2011, 13:00
  2. CDTI Spanner light after cold starts
    By Teapot in forum Engine & Drivetrain
    Last Post: 30th December 2010, 00:02
  3. Cold weather causing spanner warning light to come on???
    By supersione in forum Troubleshooting
    Last Post: 18th December 2010, 15:58
  4. Car spanner light on cold start
    By gman999 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 20:18
  5. 54 reg 2.0 dti spanner light on cold start
    By StephNET in forum Engine & Drivetrain
    Last Post: 8th January 2008, 22:04
