Thread: Doing a major service this weekend
    Sep 2009
    Swindon
    Default Doing a major service this weekend
    Going to service my new vectra this weekend, it has 65k on the clock and according to the service history had it's last service at 17k!!!
    So I need to change everything, so far I have ordered the following parts
    oil filter
    air filter
    pollen filter
    fuel filter
    front wiper blades (eurocarparts didn't have a rear one)
    rear pads (mot fail)
    FRONT LOWER SUSPENSION ARM WISHBONE (mot fail)
    5 litres of 5w30 fully synthetic oil.
    1x 69p thermal fuse for the blower
    I am also going to clean the EGR and boost valve as the car lacked power on the drive home, I plan to do the cam belt, waterpump and coolant at another time.
    So should I add anything else to my list that needs doing?
    Frenchman
    Regular Member signum03's Avatar
    worthing
    personally i would engine flush also, especially as so many miles have been covered since last service, other than that i think you are there!
    Sep 2009
    Swindon
    Cheers Signum, last time I owned a diesel I would put in about a cup full of Diesel into the oil and let it tick over for 10 minutes then drain it with the oil. Anyone use this method or is a recommended product the way to go?
    Frenchman
    Glasgow
    If u wanna go mad you could do the gearbox oil aswell or am i just giving you more to do lol.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    coolant change, brake fluid change, also time to think about cambelt if its a cdti?
    Sep 2009
    Swindon
    I am going to change the cam belt and water pump as a separate job, so will change the coolant then. Will do the gearbox oil, clutch and brake fluid as well then while I have the overalls on .
    Don't think I will bother with an engine flush as I have no idea when the oil was last changed and could end up causing more problems.
    Frenchman
  1. 4th service (major)
    By rob warrington in forum Diesel Engine related
    Last Post: 12th September 2012, 20:21
  2. Major Service Due NEED Help !
    By Elahi_786 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 17:20
  3. Major Service
    By danno in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2010, 22:04
  4. Major Service
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2008, 16:56
  5. Major Service
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2007, 20:51
