Results 1 to 10 of 16
Thread: Why is the display saying F?
    Regular Member bjorn100's Avatar
    Aug 2007
    Norway
    Default Why is the display saying F?
    The instructionbook (manual) says F = Fault. Okay, but what to do with it? Earlier the F did go back to normal, meaning it showed what distance I could drive before I had to buy Diesel. Now it seems to be stuck at F, and has been so for a couple of weeks. Is there any tips to reset or make the F(ault) go away? See photo.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its done it twice to me mate, once when the ABS plug needed cleaning but it more commonly happens when the loom has come unplugged from the outside temperature sensor in your front grill. My moneys one the temp sensor being unplugged.
    May 2006
    scotland
    It means ******* my friend!!!. Seriously, I dont know but when I am re-flashing my ignition memory map, the F appears on my trip momanterily so its like some sort of fault indicator.
    Last edited by bigmac; 1st December 2009 at 19:36. Reason: The swear filter is there for a reason please use it !!
    Aug 2007
    Norway
    Default F = Fault, but multiple?
    Thank you for your comments: Yes,
    - Wickedwillie, Fault is what the instuction-manual says, but that's it. And
    - Rushy, do you really mean that the F could refer to other faults than fuel? The display always tells me in this place (where the F is) how far I can drive before I have to refuel, based on the computer's input in how much fuel is left, and how I drive (economic or not) - so the display is of course dynamic: When I just filled the car up with fuel, the amount is over around 1100 km (left to refuel), and then it counts down as I am driving. And as you can see, the F refers to "km", and "Rekkevidde" is Norwegian for "Distance left" or something similar to that. Any thoughts?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    The 'F' is indeed a generic fault code which can have numerous causes. It comes up if I update my BSR remap, which would suggest that it detects that the ECU is being accessed from an unexpected/unknown source. I also get the power steering fault light. But neither of the 2 'faults' are indicated after the remap is completed.
    It could I suppose be a fault associated with the trip computer.
    Regular Member shadow's Avatar
    Mar 2007
    Rotherham
    I to have an F displayed, where the outside temperature reading should be.
    This has only occured since my wife hit a small wall with the offside front end.
    My dilemma is do I get the car looked at, or shut of the wife.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    This happpened to me and all I did to get rid of it was disconnected the battery for a few minutes then re-connected it and the TEMP appeared again.hth
    Mar 2007
    Rotherham
    Quote Originally Posted by BLACK KNIGHT View Post
    I will give that a go tomoz, cheers mate.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by shadow View Post
    No probs bud,let me know how you get on.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Of course it might help if this fault indication remains, to get it bunged on Tech2 or Op-Com and see what codes (if any) pop up.
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. mp3 on display
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 14:54
  3. PS3 display
    By @ndy-e in forum Games Room
    Last Post: 27th December 2010, 08:21
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. LED DIsplay
    By dcraigen in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 10:16
vectra c display FKM
vectra c temperature sensor showing farenheit
