Thread: Dipped beam
    Sep 2009
    Glasgow
    Default Dipped beam
    Any one else find their dipped beam too low on the road and not very bright and anyone have a solution to fix this apart from a hid kit, is it worth while adjusting them both slightly up or take it to a garage as i think it only costa between £10 £15 pounds.
    Try Duncan's suggestion of upping the headlight beam slightly. It worked for me.
    http://www.vectra-c.com/forum/showthread.php?t=33655
    Regular Member RobW's Avatar
    Tain - Easter Ross
    A couple of flaws in your ideas.
    A garage will not adjust the headlights above the legal level and HID's are brighter but will not give a longer beam, they will just make things brighter where they shine.
    Follow the link above to see how things are done.
    If you know a garage then you could try and pull a fast one and adjust the lights down on the dash then go in to get them adjusted. The mech might not check that before working
    Sep 2009
    Glasgow
    Will give duncans suggestions a go thanks for above help.
    Sep 2009
    Glasgow
    sorry to be a pain noticed duncans instructions are for pre facelift mines in the facelift version, I take it the instructions will still be the same.
    Oct 2006
    Wellingborough
    Yep, same method. i set my old position 0 (highest) to position 2, and now generally use position 1 (so slighlty higher) and 0 (quite high) if on unlit country roads where there;s other traffic (so no full beam). works fine for me, though AFLs would of course be the real answer...
    Quote Originally Posted by nokiaman1978 View Post
    Yes, pretty much the same. The adjuster screw is the inner one of the two that you can see looking down at the slam panel. You'll need an allen key (can't remember what size) and the adjuster is quite coarse so don't go mad and start turning the screw like a madman. IIRC, it only took less than ½ a turn of each adjuster screw to raise them back up the same height as before.
  1. One dipped beam dimmer than the other...
    By y2joeyb in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 15:45
  2. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  3. Dipped beam adjustment
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 07:06
  4. No dipped beam symbol???
    By pedro83 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2010, 23:03
  5. Dipped beam bulbs?
    By Humph Backbridge in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 22:07
dipped beam symbol vectra c www.vectra-c.com
