Thread: missfire
    glasgow
    Default missfire
    hi can anyone help me on this my vectra has a missfire only when the engine is idling ,it drives well seems to have the usual power ,revs up fine but the problem is it ticks over at about 784rpm and sounds as if its missfiring ,i pluged the opcom in and nothing came up but it goes in for its retest tomorow but they cant do an emissions test if it has a lumpy idle,opcom didnt even say which cylinder it was missfiring on
    glasgow
    glasgow
    can anyone tell me where the throttle positioning sensor is the garage had it come up as a fault along with another list of things could this cause a missfire or rough tickover
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    possibly a coil pack?
    glasgow
    i thought that too but thought his computer would have said somthing about it, he mentioned o2 sensor and throttle positioning sensor but said i would need vauxhall to look at it as it would be like looking for a needle in a haystack for the prob
    glasgow
    anyone know where it is ive lost my haynes manual [TPS]
    Quote Originally Posted by alexgrfc View Post
    tps is self contained within the throttle body am sure mate..btw what engine do you have..as for the lambda sensor any garage can check its operation correctly even with the basic of diagnostic equiptment.
    glasgow
    its a 1.8 52 plate m8 not sure what engine code
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i had a similar problem on my 1.8LS, it turned out to be my coil pack and EGR valve.
    I replaced the coil pack, made it slightly better, then blanked off the EGR valve, and the car now runs better than ever, alot smoother.
    glasgow
    thanks guys is there any threads on blanking off the egr ive done it on a deisel but never a petrol and not sure how its done
  1. 2.8 Missfire
    By Ziggy in forum Engine & Drivetrain
    Last Post: 27th June 2012, 20:07
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  4. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
  5. 1.8 missfire.
    By 16vVec in forum Engine & Drivetrain
    Last Post: 19th September 2008, 20:02
