Thread: any house alarm fitters on here help needed
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default any house alarm fitters on here help needed
    hi there i have a response wireless alarm system 433mhz fitted but the cats keep seting it of so need to upgrade the pir detecters to pet friendly ones i need to know if any make will fit as long as there 433 mhz as seen some on ebay.
    thanks in advance dean
    Feb 2007
    North west
    Cats can climb on top of sofas, window ledges, onto old tv's etc. Not sure passives with pet safe are ok for cats - they just project the beams higher.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    Quote Originally Posted by rob 2.2dti View Post
    apparently it goes on the weight upto 25kgs how it works is beyond me.
    Mar 2007
    North East
    Pure passives are a PITA if you have cats, try and get dual technology ones, even those will probably need masking but should be less prone to false alarms.
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Unless your cat(s) stay on the floor nothing will work I'm afraid.
    The petsafe ones are in effect desensitised a little so that it takes a fairly large body to trigger them. Unfortunately a small body a bit closer will also do the job.
    Dual technology ones are intended to cope with adverse conditions such as sunlight, warm air from radiators, flapping curtains, washing machines and the like. Great for minimising false alarms but absolutely no benefit for avoiding cat triggering.
    Best possibility is to restrict the cat to a single room where it can't get anywhere near the sensor. Use a petsafe one for that room and set it so that the beams don't reach near the floor. If you know how, set the PIR so that it needs to count say 3 pulses before triggering too. Better still keep one room where you don't mind not having a sensor at all or programming it to omit when the cat is at home.
    Actually that's the 2nd best possibility. Best is to shut the cat outside. I have a cat and I keep it in the utility room which doesn't have a PIR.
    HTH.
    May 2007
    West Yorkshire
    As above, you will have fa's with a cat, especially a free roaming/jumping one. best bet it to limit to one room without trap protection, usual place is kitchens.
  1. Help needed alarm
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2011, 14:57
  2. House name plate needed
    By BoroDave74 in forum The 'Off Topic' room
    Last Post: 8th May 2009, 22:04
  3. ****** house alarm.
    By shan in forum General Chat
    Last Post: 16th March 2008, 06:37
  4. House Burglar Alarm Help needed!
    By AndrewTi in forum General Chat
    Last Post: 26th July 2006, 08:56
