Thread: Headlight switch
    gwent
    Default Headlight switch
    Can someone help me with my headlight switch i had to take it out to remove under the dash when i put it back in headlights stay on when the engine is on and the light switch is off
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I had this and it sorted its self out, try disconnecting and reconnecting again
    gwent
    i tried this but it's still the same even when the engine of if you turn the lights on there is no warning sound you left your lights on?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    do you have the wire block in the right way? just a thought as i had done this before
    Full Member paul.sessions's Avatar
    leighton buzzard
    try takin out and putting back in with twisting the switch
    milton keynes
    did you take the switch apart?
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you took the switch unit out, have you trapped / damaged any of the conductors.
    Also have you fully seated the switch block back in so that it latches when you turn the switch back to the off position.
    Try pulling the whole switch block out or pushing it back into the dash until it latches into it correct location.
  1. headlight switch
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2012, 18:46
  2. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  3. headlight switch WTF
    By sxigaspete in forum Bodywork & Interior
    Last Post: 23rd May 2010, 01:23
