Results 1 to 10 of 23
Thread: Petrol in Diesel!
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Default Petrol in Diesel!
    the wife just rang to say she's put just under a litre of petrol in our 2.2DTI . then realising the mistake has filled it up with V-power diesel. (only had 20 miles distance left or so) so i'm assuming at least 45L of diesel on top of the petrol. I'm guessing it should be ok... but looking for reassurance/suggestions
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Wierdly a mate of mine did the same, 1ltr of petrol then filled up the rest with diesel - his was fine, slight chug on startup but that was it.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Quote Originally Posted by P-Mutton2.2 View Post
    I wouldn't worry about this level of contamination mate. Keep topping it up with diesel as you use it and stick a new fuel filter on it shortly you'll be fine.
    My Old Dear filled her Rover 75 to the top with petrol and drove it till it stopped. I emptied it, fuelled it with diesel and changed the fuel filter it's been 100% ever since and that was well over a year ago so less than a litre is nothing.
    Doesn't stop you giving her a sore time over it though!!
    Aug 2009
    Frinton on sea
    Cheers fellas
    did think it would be ok but y'never know.
    To be fair she was pretty upset, think she thought i'd go spare but i'm a calm kinda guy..
    Glasgow
    If it was such a low amount then i would'nt worry about it.
    I have known people put a small amount of petrol in a diesel as they think it runs better, never tried it myself.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Be careful bud - I've been warned with my 2.2 as the DTi's have very high pressure pumps that use the diesel to lubricate itself, so petrol strips this out and the pump can seize. DTi pumps are roughly a £1000 a pop!!!
    When I got mine in April I had starting issues, when my mechanic stripped the pump he found remains of petrol in it, cleaned it through including all fuel lines and all been ok since, but at first thought the pump was shot. The starting issue was leak-off / injectors seals in the end, but the pump scared the life out of me, I'd only owned the thing for 3 weeks at that point!!!!
    Regular Member BoroDave74's Avatar
    Attleborough
    Mis-fuelled my old td escort with £20s worth of unleaded into half a tank, let it settle and drove ten miles to my garage for a drain and filter change, cost me an hours labour Car ran fine and did another 20k miles before I traded it in for my vec.
    So you could be fine...however someone I used to work with misfuelled his brand new freelander from empty to brim, turned the ignition and wrote the engine off, £7.5k. His insurance did cover misfuelling...might before worth double checking your fine print. hth
    Regular Member Readster's Avatar
    Plymouth
    Or..you could play safe and drain the contaminated fuel amd re fill with fresh diesel.
    I know its a waste of money but what price peace of mind?
    Quote Originally Posted by si_hoss View Post
    Try 3k on the 3.0cdti! Thats why I changed to petrol!
  1. petrol or diesel
    By kram1000 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2011, 15:10
  2. Diesel Vs Petrol again..
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2008, 09:15
  3. PETROL vs DIESEL?
    By vectrahuw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 00:07
  4. Diesel and Petrol
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 22:29
  5. Petrol vs Diesel
    By kryton01 in forum Diesel Engine related
    Last Post: 14th September 2006, 06:49
