Results 1 to 10 of 11
Thread: Passenger front door?????
    Oct 2009
    UK
    Default Passenger front door?????
    Hi, I have just recently purchased a 55 plate Vectra C SRI. I have had five vauxhall previously but this is a new one to me!
    My son opened the passenger front door and the interior courtesy light came on then promptly went off. He closed the door and I noticed the electric window operating panel on this door was no longer illuminated. I tried to open the window using this switch but it didn't work, neither did the switch on the drivers side for the passenger window. The central locking wouldn't operate the door button up or down and I am getting a message on the display screen regarding the alarm system when I start the car?????
    Can anyone help......Please.
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Passenger door module fault or wiring fault in this area.
    Tech 2 diagnostic will be needed.
    Has any work been done in this area of the car?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    could be a couple of things from a broken main wire in the door to the passenger door module (window switch) or door catch. might be best to get properly checked by a dealer and cheaper in the long run too. you could try a quick system reset disconnect your battery for 5-10 mins doesn't cost anything to try.
    Oct 2009
    UK
    No work done on any electrics nothing has been disconnected or touched.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    dosn't need to be. cause the car has 20ish electronic control units they can get mixed up some times
    Oct 2009
    UK
    If I try the system reset will it upset anything else??? Will I need to enter code etc for cd70??
    Cheers.
    Basically nothing electrical works on that particular door nor does it operate the courtesy light when opened.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no on a 55 plate the radio is programed to the car and doesn't have a seperate radio code. just put your radio stations back in and hold all window switches up for 5 sec to reset them
    Oct 2009
    UK
    Thanks alot will give it ago in the morning and let you know. Cheers.
    Oct 2009
    UK
    Default Phew!!!!!!!!!
    Cheers mate it turned out to only be the plug that attaches at the door hinge. The clip is missing off the plug which stops it falling out, it was dark and p*****g down last night and I couldn't see. I got a bit excited having only just got the car and found a few other problems. I jumped in at the deep end assuming the worst.
    If you don't mind me asking do you have any information on seat belt tensioners. The passenger one has been deployed. Is there anything I can do, get another and fit, reset it or does it have to go into a dealer to be replaced???
    Thanks again.
    Darren.
    Mar 2007
    North East
    Dealer job for the tensioner's I believe. Thought it brought up a warning in the air bag ecu ?? Could be that someone has mucked about with the electrics.
  1. How to fit Front Passenger Side Door glass
    By thehoq in forum Bodywork & Interior
    Last Post: 14th March 2013, 15:59
  2. Replies: 32
    Last Post: 2nd January 2013, 02:18
  3. changing the front passenger door
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 10th September 2011, 19:07
  4. need a new passenger front door
    By ade in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2008, 10:25
