Thread: ELM 323 Interface
    Sep 2009
    Swindon
    Default ELM 323 Interface
    Has anyone been sucessful in using one of these interfaces to read DTC from a vectra c? I have tried with scantools and one of these cables but without luck.
    I know there is a ELM 327 cable also but not sure if this is compatable either, anyone use an interface cable in conjunction with a laptop to read codes?
    Frenchman
    Regular Member bigbnlr's Avatar
    Belfast
    a mate tried his on mine with no joy. you need opcom or vauxcom cable and software
    Regular Member old cruiser's Avatar
    slough
    I've got the ELM327 and that won't work on the Vec either,used to work fine on my old 2001 Omega I had, ended up buying a U581 which reads fine and is a handheld unit, not sure if they are easily available anymore, you could try E-Bay or failing that try www.talktomycar.co.uk who sells allsorts of code readers and Mike there is a helpful chap HTH
    Cheers Pete
    Sep 2009
    Swindon
    Thanks guys
  1. ODB Interface
    By Golfboy in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 14:12
  2. My LED conversion/CID interface
    By stampede in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 00:29
  3. Can Bus Interface
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2008, 11:27
  4. Line in interface
    By kantimpalo in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2008, 13:15
