Results 1 to 10 of 14
Thread: speedo not working
    Sep 2009
    warwickshire
    Default speedo not working
    hi their. my speedo and the cruise control are not working on my 2.2 dti sri.dose any one know how to test if it,s the speedo head.i cant afford to go to the dealers. just spent all my money on a injection pump.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I would take it back to the garage who fitted the pump etc...
    Sounds like they have disconnected the loom for the road speed sensor, whilst tatting about in the engine bay.
    You could look for any disconnected plugs in the gearbox sender area or near the front wheel speed / abs sensor (not sure which side supplies the signal to the ECU).
    That would be my first port of call!!
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As if by chance...look at this thread....someones answered your query on an identical query..
    Check the ABS connector plug as shown in the photo.
    http://www.vectra-c.com/forum/showthread.php?t=92851
    Sep 2009
    warwickshire
    thanks for the advice.i will look at the wiring plugs. and try some wd40. but if it was a abs plug fault .would the abs light would come on?. on mine its just the speedo and the cruise control and the central display.not showing range/speed. the rest of the instrument cluster works fine.could it be the speedo head ?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    try the instrument fuses I suppose
    the instrument head shouldnt fail for no reason
    Sep 2009
    warwickshire
    i have checked the things suggested on my thread. i have swapped the speedo head with another car and it works ok in that . but now i have now found that the plug into the abs pump looks as if it as been changed all the wire have been cut and rejoined. but their is one wire coming from terminal 3 on the plug that goes no ware. any ideas. or where can i get a wiring diagram.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I read in the other thread that some plugs were replaced / upgraded.due to original plug connector pins being too short and not reaching properly...yours may have had this, will look at my Vx database for the connector pinouts for this and report back as soon as I can
    What year plate is your registration
    2002 to 2004 (52 to 04 plate)
    2004 to 2005 (54 to 55 plate)
    2006 to 2008 (06 to 58 plate)
    This is important as Vx went through it's changes to wiring and components through the years
    Sep 2009
    warwickshire
    thanks that would be very helpful. my car is a 52 plate2.2 dti sri.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Wow, what a mine-field of wires that all look the same!!!
    The pins are: -
    1) white - hi speed can low to electronic stability control
    2) green - hi speed can high to electronic stability control
    3) blue/red - body and instrument panel (ESP switch)
    4) not connected
    5) not connected
    6) not connected
    7) Blue/Red - to X26 connector pin 11 (body and body front) Fr Rt whl speed sensor
    8) Brown/red - to X26 connector pin 12 (body and body front) Fr Rt whl speed sensor
    9) Blue/red - to X5 Connector pin C - Rear Rt whl speed sensor
    10) Brown/red - to X5 connector pin D - Rear rt wheel speed sensor
    11) BROWN - Chassis / earth
    12) RED - Permanent Live - Engine fuse box - Fuse FE32 - 40 amps
    13) White - Hi speed can low - ABS and Power Steering
    14) Green - Hi speed can high - ABS and power steering
    15) No connection
    16) No connection
    17) Black/Yellow - Stop lamp switch
    18) Blue/Red - Radio and navigation (Speed dependent volume signal)
    19) Blue - X26 Connector pin 13 - front left wheel sensor
    20) Brown - X26 connector pin 14 - front left wheel sensor
    21) Blue - X5 connector pin A - rear left speed sensor
    22) Brown - X5 connector pin B - rear left speed sensor
    23) BLACK - Ignition live - Engine fuse box - Fuse FE16 ..7.5 amps
    24) BROWN - Chassis / Earth
    25) RED - Permanent Live - Engine Fuse box - Fuse FE29 ...40 amps
    no further connections listed.
    Hope this helps!!
    Sep 2009
    warwickshire
    many thanks that will help a lot. all i have to do now is find what has happened to number 3 , it is sticking out of the plug ,but is not in the loom. this car as been messed with badly before i got it.
    i may have to run a fresh wire to the esp switch/body and instrument panel. . i will let you know how i get on. Many thanks
  1. Speedo and rev counter stopped working ??
    By Knuckle in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 16:59
  2. Help with the speedo clocks keep not working
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:01
  3. speedo not working
    By garymercbham in forum Engine & Drivetrain
    Last Post: 18th October 2009, 18:34
  4. Speedo & Mileometer not working
    By BigTunz in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2008, 00:29
  5. Speedo stoped working!!!!!!!
    By rsorion in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2007, 20:55
speedometer not working in vauxhall signum 2006
vauxhall vectra c speedometer not working www.vectra-c.com
vectra c speedo not working
vauhall sigma 2009 speedometor stopped working
vauxhall vectra speedo not working
