Results 1 to 10 of 20
Thread: new pads - how much!!!!
    Regular Member wardy's Avatar
    Chichester
    Default new pads - how much!!!!
    Dealers want £160 to change the front pads on my 3.0. They are big pads, but bloomin hell does that sound expensive to you?
    Regular Member signum03's Avatar
    worthing
    just change them yourself, hour job both sides, even a how 2 on here to do it!
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    That does sound a lot. An hours labour @ £40 makes the cost of the pads £120 - which is far too much IMO.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    our local vx stealer now charges £80.00 per hour + vat minimum 1 hour charge (now that's how to make money!)
    Pad and disc kit for the V6 models is 72 squid + VAT. There's bound to be someone near you who can do it for you though, and if not I can pop down from Oxford for a small fee and sort you out...
    Chichester
    would have done the job myself, but don't have the tools (rewind tool, axel stands etc etc).
    Thanks for the offer Penfold, but it's a long way to come for a set of pads.
    Think I may ring another dealer just to check.
    11 Post(s)
    You don't need a rewind tool for the front pads. You can also improvise if you haven't got axle stands. Throw an old wheel or block of wood under the sills in case the jack slips. Changed many a set of pads with just the jack alone and made sure that no part of my body is EVER under the car should it slip or let go.
    No need for rewind tool on the fronts mate, just a way of bleeding them if you disconnect the hoses (which is the easiest way to push the caliper back in in my experience...)
    Chichester
    ah, thought the how to, which referred to rewind tool, was on the fronts. May give it a go then.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    82 quid for the smaller ones on my 1.8
  1. Which pads???
    By Stevie76 in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2012, 00:37
  2. Vxr pads
    By tbs in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2011, 00:07
  3. New discs and pads or just pads
    By dannycturbo in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2011, 20:09
  4. New Pads?
    By Exotica in forum Suspension, Wheels & Brakes
    Last Post: 21st September 2010, 13:57
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
