Results 1 to 10 of 18
Thread: possible wastegate actuator problems
    WGAF#5
    Exclamation possible wastegate actuator problems
    afternoon all ....
    lovely weather for ducks today!!
    as some of you may know i had a remap about 2 months ago now and love the difference to the performance ....but immediately following the remap i would intermittantly get a eml fault and the turbo would not run this hesitation can occur from 3rd gear to 6th gear for example....under harder acceleration in 3rd gear - steady acceleration in 4th or when you attempt to push on ..say 70 mph in 6th (2500rpm)and press the accelerator - but the fault is soooo intermittant it wont happen at the same place every time on the same journey some days i can drive to work with no problems and the next day eml will occur......weird but makes you think twice about attempting to make an overtake when the turbo COULD drop out at any moment....
    the fault can be cleared by turning off the engine and restarting - car then drives perfectly normally - for a remap
    diagnosed as fault code P0244 so as per previous threads and contact with other members with similar issues and great advice from the Darrell at Torquing bhp i ordered and replaced the solenoid valve - only to have the same issue
    i contacted Darrell again and he thought the fault may be hard stored and hence why it was still present - and we arranged to have a another run and possible softer remap incase the solenoid valve was oversensitive...
    this was completed and today (long delay owing to us both being fairly busy and today being the first availble time we could get together....we again went out only for the same fault to occur - have the same fault code stored as initially so thinking what else could it be.....
    Darrell has suggested the Turbo wastegate (i would like to say Darrell has the patience of a saint and has been very helpful) to see if its sticking ....
    but how can i test this ?? if it needs replacing there roughly £150 so would like to rule it out before i order one and find its not needed....
    possible turbo pressure sensor ???
    hose leak - would have thought it would occur all the time and not intermittantly ?? cant hear anything obvious -
    your thoughts and suggestions would be greatly appreciated
    so over to you
    please help
    WGAF#5
    anyone think the airbox mod could affect this ??????
    or maybe a mis routed pipe ???
    WGAF#5
    bump for the evening masses.... till its off the screen in the next five minutes!
    Regular Member Jezzy's Avatar
    S.E
    As it seems non of us have answers for you, might be worth posting on the saabscene forum as well - it is an engine developed by Saab after all and a lot of the bods over there have this engine. I found them to be a helpful bunch when I was looking for help with the solenoid valve issue.
    WGAF#5
    cheers Jezzy - will pop over - ........but i'll be back
    S.E
    FYI, the Saab boys don't call it a Z20NET, to them it's the B207L.
    WGAF#5
    you star !
    Regular Member Swaite53's Avatar
    South Wales
    I'm sure it's not related, but it may give you another avenue to explore. I had very similar symptoms with mine a while back.
    I don't know what the fault code was, as I didn't read it myself, but the problem was ignition module 1. This was damaged by myself while cleaning the engine bay (didn't cover the sensitive bits as well as I thought), and produced very similar symptoms to yours.
    Full Member gibbon7000's Avatar
    lincs
    Dez, have you had any joy with your problems? Dont think it'll have anything to do with the airbox box as I've done that and had no problems. Could it be the barometer sensor? There about £15 from the dealers. Have you had VX tell you what P0244 fault code is?
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    WGAF#5
    Kev,
    if it stopped raining long enough when it was light for me to have a look and check it would be great
    the fault was as and is P0244 turbo/supercharge wastegate regualting solenoid /valve A range performance
    which is why we replaced the solenoid valve - first as the cheapest (and in the other cases the resolving factor) -
    i need to test my wastegate acuation - not sure if i can manually "move" it or try and feel if there is any resistance as you can only really do it by touch and preferably when its cold as trying to feel the movement with hot parts is painful - i might have to remove the turbo heatshield for a little better access - but its going to be sunday before i can attempt - again weather permitting -
    ive been wating for a while - so a little longer wont hurt - but thanks for asking !
    i'll keep you posted
    regards
    Dez
  1. tubrocharger wastegate
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 18th March 2012, 10:17
  2. Signum 2.8 turbo wastegate actuator
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 08:22
  3. gt2252 actuator problems
    By chesh1980 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th November 2011, 11:49
  4. Chirping Wastegate...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 11:17
  5. swirl actuator problems
    By ziggi in forum Diesel Engine related
    Last Post: 28th August 2009, 11:47
z19dth wastegate problems
