Thread: Can't remove the rear wheel!!
    Regular Member C9_hardlatch's Avatar
    May 2007
    Default Can't remove the rear wheel!!
    Afternoon all
    Trying to change my brake pads and discs and hit a minor snag in that the rear offside wheel won't come off, its stuck fast. Any body else had this problem and have any suggestions, apart from brute force and ignorance.
    Regards
    Neil
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Nah, give it a measured kick around the edges - it will loosen and come off.
    Put the wheel bolts back in so they're done up but not fully tight, then lower the car back down. Move it a foot or two forward a back and this should be enough to break the bond. If not, loosen the bolts a bit more and try it again...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Failing that use a block of wood and a hammer to knock the rim from the back but have someone there to catch it or place a soft cover on the ground
    WGAF#5
    pretty much covered as above
    most garages have asoft faced mallet or hammer for just such a case of sticky wheels
    lightly bang around the inner rim with the nuts loose (if working on your own)or out if two people present and it will come free - remember to apply some copper grease to the rear of the alloy around where it will seat over the hub before refitting - will help prevent it sticking again
    Mileage : 000
    Have a read of this. See if it is any help.
    http://www.vectra-c.com/forum/showthread.php?t=31309
    Regular Member Bloicy 3.2 V6 GSI's Avatar
    Aberdeen
    sit on your backside and give the outer edge of the wheel / tyre a good kick with the sole of your foot on either side alternatively untill it frees itself. Worked everytime i have done this. HTH
    Edinburgh
    or as above a soft faced mallet
    then when you put them back on, put some copper grease on the back of your wheels.
  1. How do i remove auto fly wheel
    By neill in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 10:22
  2. Need to remove locking wheel nut
    By SRI_STU in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2010, 11:21
  3. How to remove steering wheel controls
    By bnam in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2008, 14:29
  4. How do I remove a steering wheel?
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 16:02
  5. Remove Steering Wheel
    By archerz in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 21:33
cant remove vecra c rear wheels
