Results 1 to 10 of 24
Thread: Header tank problem V6DTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Header tank problem V6DTi
    Eh, yet another thread about my problems lol
    Today's problem seems to be around coolant. It looks like there is an air lock somewhere in the system. I'm losing coolant, the cap takes a lot of turns to tighten, oil and coolant are not mixing.
    There is nothing or very little amounts of fluid coming from the top hose on the header tank.
    The engine is not overheating.
    Any suggestions?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Bump!
    Drain and fill it again with the heater on hot?
    Regular Member Jezzy's Avatar
    S.E
    If you're losing coolant and the cap takes a lot of turns to tighten, maybe the threads on the cap are damaged - could be worth buying a new cap.
    Northampton, UK
    I had this sort of problem this week, turned out I had to have a new water pump fitted as it was leaking from there, but only when hot and on the move. The car never over heated and would go 250-300 miles before the low coolant light would come on.
    Riga, Latvia
    anyone knows what the difference between header tanks Y30DT and Z30DT ?
    in the beginning both have header tank part number 13 04 236.
    then Z30DT changed to part 13 04 612, same as Z28NEL, Z28NET
    and now part number 13 04 612 is changed to 13 04 274.
    maybe it's time to change that old Y30DT header tank to new part? maybe it cause all the problems
    Riga, Latvia
    look at that http://www.saabcentral.com/forums/sh...=163564&page=5
    i know it's saab 2.8, but the same header tank part number GM 12842086 (opel 13 04 274)
    what do you think about these hoses. crossed or not?
    Every time I have had the coolant replaced the coolant cap was replaced at the same time
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Just a quick suggestion with a problem I had with mine.. how far are you filling it? I went to Opel after a new header tank fitting as coolant kept coming out of the overflow hose.. They said it was an air lock and they had to use a 'special tool' to fill it with coolant.. turns out that I was over filling it and they mugged me off for 60 bucks.. :
    If its the same tank as the 2.8 Petrol engine which is not see through, it only needs filling upto the half way point where the seam for the two moulds is. I learnt the expensive way. Give it a go anyway. rockon:
    Riga, Latvia
    i think Celes have an old style header tank.
    just like that
    but new
    i have the same problems with coolant. no leaks, no smoke, no overheating.
    i have changed termostat, coolant and header tank cap.
    that is why i'm thinking about to change to new style header tank and hoses
  1. Pressure in Coolant Header Tank - Problem?
    By ph67 in forum Y & Z30DT Specific
    Last Post: 18th October 2012, 14:18
  2. header tank cap??
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 23:15
  3. z32se header tank....
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 23:18
  4. header tank cap
    By animal22 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 14:52
  5. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
y30dt coolant leak
