Likes Likes:  1
Results 1 to 10 of 26
Thread: 2.0t turbo fault code P0034
    Mar 2007
    aberdeenshire
    Default 2.0t turbo fault code P0034
    hi, can anyone tell me the likley cause of fault code P0034
    turbo charger bypass valve control circuit low.
    Full Member KitS's Avatar
    May 2016
    Lydney Glos
    Engine : 2.0 T
    Mileage : 134000
    No replies after 9 years doesn't bode too well for my question......
    My Signum 2.0T Design has exactly this problem too. During a longish trip the engine hiccupped and various lights came on and then went off again, and afterwards the car was notably down on power, none of the usual 'zing' at all. I took it to my local garage guy, not a VM dealer, and his diagnostic box coughed up the same 'fault code P0034 turbo charger bypass valve control circuit low' fault.
    When we checked the bits under the bonnet the vacuum operated valve to the left of the turbo, looking from the front, didn't seem to operate at any throttle setting, but it did operate, pushing outwards, when subjected to a separate vacuum supply. There's some sort of electrical device (solenoid?) outboard of the vacuum valve, but as this is a SAAB engine none of his Vauxhall docs seem to have any info on it.
    There's no smoke from the exhaust and it runs OK, but just like a non-turbo'd 2.0 engine.
    Does anyone have any clues to what the problem might be please?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    I am not familiar with the Z20NET. It sounds like the vacuum servo you mentioned is not operating. The solenoid that sends vacuum to the unit might not be operating. It may have failed or there could be a wiring fault. Or a blocked vacuum pipe. You have to start somewhere.
    Hopefully one one of the Z20NET experts will be along. @Caveman_nige?
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    There's 2 of them on the Z20NET - General consensus is to replace both of the boost solenoids at the same time, belt and braces. They're about £20 each.
    May 2016
    Lydney Glos
    Engine : 2.0 T
    Mileage : 134000
    Ah, great, thanks for that.
    Where's the other one please? I can see one of them mounted to the left of the vacuum cylinder, looking from the front of the car, but I can't see another one. I'll post a pic later on today to show what I mean.
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Not done mine yet but from memory there's one near the TB and one near the turbo wastegate.
    May 2016
    Lydney Glos
    Engine : 2.0 T
    Mileage : 134000
    Thanks, my garage man will have a look at it tomorrow.
    My days of digging down behind sideways engines are long past.
    May 2016
    Lydney Glos
    Engine : 2.0 T
    Mileage : 134000
    Here's a pic of the bits I THINK are the problem.....
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Yep, one of the solenoids is there, the other is at the front of the engine on the left of the inlet hose.
    There's also a diaphragm in the charge air bypass valve which is bolted to the turbo which can split and cause all sorts of running issues if neither of these clear the issue.
    There was a thread on here that had the part numbers for both valves in somewhere, just be careful not to mix them up as they look the same but are different.
    Dec 2015
    Yorks
    Trim : Mohican
    Engine : Z20NET
    Found it - links to other threads in it with part numbers.
    https://www.vectra-c.com/forum/showt...-2-0T-No-Boost
  1. P0034
    By tda1610 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th February 2013, 22:38
  2. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  3. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
  4. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  5. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
vectra 2.0 turbo 0034 code
code P 0034
https:www.vectra-c.comforumshowthread.php93947-2-0t-turbo-fault-code-P0034
