Thread: Help i need a new engine
    Regular Member andyman201's Avatar
    Middlesbrough
    Unhappy Help i need a new engine
    Help i need a new engine do i just look for the z19dt code on the side of the engine
    Wales, UK
    Take a look on the like of ebay, type z19dt engine and make sure you try breakers. I was looking for one recently and garages always seem to get confused with the z19dt so they are about. Any breaker will work with the engine code.
    Good luck !!!
    Middlesbrough
    hi mark will this be ok do you know?
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item255245e959
    Full Member Big Sig's Avatar
    Depends if yours is a 120 or 150
    Middlesbrough
    my one is 1.9 cdti 120 8v 04reg engine code: Z19DT
    6speed i just rang them they said it had a 6speed box on bit it was sold so the engine is now out in a pallet
    they were all 6 speed i think. It would probably be ok as its the same engine, what does it some with?
    Full Member gibbon7000's Avatar
    lincs
    try megavaux at Nottingham mate, they might have something
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    scotland
    Middlesbrough
    i got one from close to me getting it fitted on mondy they said it will take 2-3days and fitting was £250 dose that sound about right.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
