Results 1 to 10 of 17
Thread: If stuck, could you use washer fluid to replace coolant?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default If stuck, could you use washer fluid to replace coolant?
    Hyperthetically, if you had a coolant leak and it was freezing cold, could you use a strong solution of washer fluid as a stop gap?
    Would it cause any damage?
    Wales, UK
    mmm, dont think a top up would hurt it really but I wouldnt like to try lol
    Oct 2007
    south wales
    Just wondering what the difference there is in the composition. I think coolant has additives to stop corrosion etc, both have glycol or somesuch to stop freezing.
    I wouldnt want to try it either, just wondering.....
    8 Post(s)
    Surely it would just bubble and foam?
    On the plus side, you'd have a squeaky clean cooling system
    Regular Member signum03's Avatar
    worthing
    no, no,no.no,do not do this!! keep anti freeze stocked up!
    Full Member Big Sig's Avatar
    if its just to get you a short distance, just use water.
    worthing
    as above, alot safer
    Wales
    As Big Dave said - I imagine bubbles and foam woudl be your biggest issue. Personally, I would rather pee in it!
    worthing
    Regular Member Swaite53's Avatar
    South Wales
    I wouldn't put screenwash in there. Surely if they were the same, then it would be sold as a multi-purpose product. There are no cooling or anti-corrosion aids. This time of year, I wouldn't run it on water only either, as you never know when the weather will make a quick change and get really cold. Could get up one morning next week and it's -6.
    A mate of mine a few years back had a Volvo, and just had water only in it. One cold morning he got in and started the car, it was fine. However, a few miles down the road the engine just seized. The water had frozen and cracked the engine block - a massive cost to put right, so he just got rid of the car. All for the sake of him spending about £4, and 10 minutes work.
  1. Washer fluid check.
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 14:07
  2. Which washer fluid?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:15
  3. Replace Brake Fluid Or Not???
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 11:52
