Thread: loss of power signum
    Oct 2009
    uk
    Default loss of power signum
    hi all....new to this so please be nice
    ive got a prob with my 2004 signum 2.0l dti....every now and then i get a total loss of power and the engine man light comes on ...it will stay on untill the ign is turned off .....if i flick the key as im dirving it will go back to normal ...this will happen poss six or more times then it will be fine for ages then it will start playing up agian....id be greatful of any help
    thanks
    [Ex]Admin Duncan's Avatar
    Re your problem. Given your engine the first thing to look at are the boost pipes (big wide turbo pipe) for any splits. They may be small and not look like much but once the boost builds up they open up and drop the car into limp mode. Have a good check all over and under the pipes. There are smaller rubber vacuum pipes to check too but I can't remember exactly where they are positioned.
    Oct 2009
    uk
    thanks for that ill have a look in the morning....forgot to mention its flat as(wouldnt pull u out of bed)
    just noticed ive posted in the wrong section sorry guys
    Full Member gibbon7000's Avatar
    lincs
    to the site.
    As Duncan has said, check the pipes out first and go from there
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Quote Originally Posted by marcb View Post
    No worries, now moved for you.
    The flat as symptom is also synonymous (blimey, big word for so late! lol) with the split pipes issue.
    Oct 2009
    uk
    thanks for that duncan
  1. Signum 3.0 power loss
    By bigbazk in forum Y & Z30DT Specific
    Last Post: 15th September 2012, 14:28
  2. problem with signum 2.0 dti loss of power
    By unhappy of wales in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 21:38
  3. Signum 120 CDTi black smoke and loss of power @ low revs!!!!
    By siw8158 in forum Engine & Drivetrain
    Last Post: 29th July 2010, 17:08
  4. Signum 2.2 DTi cutting out/ loss of power
    By muzmayhem in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 15:14
  5. 2.2 Direct Signum Petrol - Loss of power
    By Binksy2.2Direct in forum Engine & Drivetrain
    Last Post: 9th July 2009, 00:33
