Results 1 to 10 of 18
Thread: VX Tech 2 Costs
    Default VX Tech 2 Costs
    OK, I admit before going any further that its not Vectra related but, my astra mk3 that is my non-taxi car has a bit of a fault my mechanic mate cant pinpoint so we think taking it to a dealer and tech 2-ing it is the only answer.
    Try to start car, the ignition comes on fine, stereo comes on, heaters, electric windows work, everything, and the car turns over fine but wont start. also when you turn the ignition on the engine management light starts flashing and wont stop, obviously whatevers causing the light to flash is whats causing the car not to start.
    hence it needs tech 2'd to find out and fix the fault, what sorta price do they charge for fault finding on a tech 2, I assume it'll take only 5mins for the computer to tell them the fault so they can fix it. do I need to pay for the mechanics time using the tech 2 as well, etc.??
    many thanks guys.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Some dealers charge an hour no matter what, most have a minimum charge of half an hour.
    Depends on the dealer mate.
    But the older Astras depends if they have a OBDII port or not? Most Snap-On and other handheld scanners will be able to read the error codes on that car no problem.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    could it be the imobiliser?
    just a quick thought.
    carl
    Hertfordshire
    Yep, my local stealer has a minimum diagnostic charge of an hours labour, refunded IF they do the remedial work.
    However, what you are describing there with the light, sounds very, very much like an immobiliser fault !!!
    not sure mate, I just know theres a unused plug in the fusebox thats for plugging the tech 2 into,.
    tbh I just wanna send the car to the garage and get it back working. its sat there for 3months with various things needing done, now there all done and all thats left is to get it started so we can get it mot'd, so we arent using our vectra taxi when we aint at work.
    yes mate according to the owners manual the engine management light flashes when theres an immobiliser fault preventing the car from starting. however we cant pinpoint exactly whats wrong with the immobiliser/causing the car to be immobilised.
    'Norf Yorks.
    You have checked fuses obviously yes mate?
    Any decent garage could diagnose the problem if they have a handheld scanner. I still have my Snap On scanner from my days and it definetely covers your car. Must get that on Ebay...
    Guys above reckon immobiliser mate and if it cranks but doesn't fire then yeah its a good one that
    'Norf Yorks.
    Quote Originally Posted by Hendry
    Ah! I must read better, bottle of wine gone here oops. LOL!
    Immobiliser ECU could of failed. Had that on Frontera. Sometimes needs reprogramming, sometimes failed altogether.
    See if you have a Vx specialist in your area, cheaper than the dealer and more often than not do a better job.
    Tech2 is normally a flat charge of £40 at my nearest stealers.. no obligation to have it repaired there as well..
    if i had to have a guess i'd say the imobiliser pickup ring ( around the ignition barrel) would be my first port of call..
    aye mate, like I say we know its deffo the immobiliser thats at fault we dunno exactly what it is with the immobiliser.
    we've checked fuses, ecu, the transponder block around the ignition barrel, key chip, things in the engine. everything we could think of, still no joy.
    basically if I dont send it to vauxhall and have it fixed for me I am gonna lose my rag and end up scrapping her
  1. And Up Go Fuel Costs Again
    By boba in forum General Chat
    Last Post: 25th January 2009, 18:47
  2. Costs?
    By JKB89 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 16:03
  3. Servicing Costs.....
    By Signum_CDTI in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2008, 12:49
  4. Costs.
    By FIL 4822 in forum Styling
    Last Post: 20th December 2007, 23:32
  5. URGENT ADVICE NEEDED! Tech 2 hasn't worked and costs rising
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2007, 20:30
